K3 battery
Posted 13/11/2013 - 15:44
It depends on a lot of other factors not just the number of exposures, but I think the K3 is rated for about 500.
Fletcher8.
Posted 13/11/2013 - 16:02
Thanks Fletcher8.
I have been scrolling the menus setting it up so that will have drained the battery. Just thought it seemed a bit on the low side.
Oldhat
Oldhat
Posted 13/11/2013 - 16:06
The manual and the speck on Ricoh web site state that the battery under normal conditions is good for 720 images.460-560 if using flash
Posted 13/11/2013 - 16:17
If its a new battery, which I guess it is, it could well take several charge cycles to get to full power.
Also being a new camera, you've no doubt been fiddling with the menus and playback more than you normally would which must take their toll on the battery charge life.
Posted 13/11/2013 - 16:32
It is the battery out of the box, so as Peter says it will need to be used a few times!!
Many thanks all for the responses.
Edinburgh
