K20D infrared?
womble
Posted 14/09/2019 - 22:03 Link
My K20D has sat unused since I bought my K-3 in 2014. Given the resale value is not very much, I was wondering about getting it converted to IR. Has anyone had a K20D converted? Any tips? Recommended workshops?
Thanks in advance, Kris.
bjolester
Posted 14/09/2019 - 22:15 - Helpful Comment Link
I also have a K20D that I have been planning to IR convert. I believe the K20D is less difficult to convert than for example the K5 (possibly due to the sensor cleaning mechanism). Anyway, this is where I will send my camera when I decide to go for an IR conversation:
https://www.spencerscamera.com/index.cfm
If you do end up with converting your K20D, please share your experiences with the process and results!
Bjørn
Edited by bjolester: 14/09/2019 - 22:16
bforbes
Posted 14/09/2019 - 22:55 Link
I avoided converting a DSLR to IR because of problems I'd read about with viewing the image. I went with a mirrorless and EVF
Posted 14/09/2019 - 23:36 - Helpful Comment Link
Have used ACS in Norfolk a couple of times... converted a K30 and a K5... did a gt job both times... am sure a K20 wld be fine...
Best
womble
Posted 15/09/2019 - 08:34 Link
Thanks guys, I'll check both out.
petrochemist
Posted 15/09/2019 - 14:16 Link
Like Barrie I went for a mirrorless model when I got a converted body. My initial one was brought pre-converted for less than the cost of a conversion.
More recently I've brought a FF body & had that converted by Alan Burch on the isle of wight. I should be able to shoot UV as well as IR with the new one, and can fit a clip in filter to return the camera to normal operation too.
I've come across a useful comparison of conversion companies on-line, giving contact details etc for each.
Posted 15/09/2019 - 19:08 Link
Try this.
158
Ricoh Japan teases infrared version of the Pentax KP DSLR, but don't plan on getting one
Published Jul 31, 2019 | Gannon Burgett
Share
158
Share
Best cameras and lenses 2019
158
Share
womble
Posted 15/09/2019 - 20:56 Link
Whatever the benefits of an IR mirrorless camera, it misses the point somewhat.
Now debating which filter to have fitted...
Thanks all. K.
Edited by womble: 15/09/2019 - 20:56
petrochemist
Posted 16/09/2019 - 18:50 Link
Thanks all. K.
The point is it might be the cheaper option as well as working much better. Even if you use an adapter to use your existing Pentax glass...
