high speed birds in flight
Posted 22/01/2011 - 17:16
you should not need a flash you should use shutter speeds of 1/1000sec and afc focus mode and good paning.
Posted 22/01/2011 - 17:27
If you use a flash your shutter speed is limited to 1/180th unless you use High Speed Synch, in which case the flash power is attenuated and is therefore of minimal use. 1/180th is not fast enough to freeze that kind of motion.
Why do you think flash is necessary for birds in flight?
A fast shutter speed is needed so use Tv mode and adjust the other two exposure variables (aperture and ISO) to suit the scenario.
Posted 22/01/2011 - 17:35
dont bother trying to use your flash, if its a dull day boost your iso up a smidge to 800, and put your camera on Av mode and leave the rest for your camera to work out, if its a bright day then dip your iso down back to 200 as most pentax cameras are unless you have a K7 or a K5.
Also use a monopod as it does not restrict your panning movement .
Hope this helps you
Shane
Hope this helps you
Shane
Camera: *ist DS,MZ-50,
Lenses: D-Xenon 50-200mm 4/5.6, pentax smc a 50mm 1.7, Kiron 70-210mm, Pentax SMC DAL 18-55, Asahi 2x Rear tele-converter, Sirius M42 135mm macro, M42 extension tubes 61mm,
Flash: Jessops 360 AFdc
MY WEBSITE
MY WEBSITE
Posted 26/01/2011 - 13:33
sorry for the delay, have been busy working shifts.
Many thanks for all your comments.
I was only going to use flash because someone told me that was what he uses. And allthough i want to take the birds in flight in the day, as its gloomy ole england it is very dark. as my k5 still hasnt arrived yet Im using the K20d. and fixed sigma 400mm lens.
I have set some bird feeders up at work and see the ltt most days. so i would like an in focus in flight picture of at least one.
Any info is gratefully recieved.
many thanks again
H
many thanks again
H
