k200d battery grip
Posted 06/12/2008 - 08:12
No problem with my grip, batteries seem to last for ages.
Have you got the grip set as primary power source?
I haven't, the camera uses which ever set has the best power output (Auto select) which could be why.
Cheers, HG
PPG entries.
PPG entries.
Posted 06/12/2008 - 11:37
yeah i did i will give it a go and see what happens cheers hardgravity
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 06/12/2008 - 22:45
Scott,
Using punctuation would make your posts easier to understand
Terry
Terry
Posted 07/12/2008 - 19:46
my battery grip still keeps saying the batteries are flat
so i turn it off and one and there fine for ages,
I have tried with no batterys in camera what so ever, just in the grip,using new charged batteries.
just keep snapping,
Posted 07/12/2008 - 21:31
Sounds like you have with your grip,
suggest trying NEW batteries then if that doesn't work,returning your grip for replacement first.
If that doesn't solve the problem then contact Pentax re your body
Cheers, HG
PPG entries.
PPG entries.
Posted 07/12/2008 - 21:35
i have tried a couple sets of batteries and its the same,
got grip from srs
got grip from srs
just keep snapping,
Posted 07/12/2008 - 22:21
I suggest you talk to SRS about your problem. With the recent praising of the company, I'm sure they will sort it for you.
Terry
Terry
Posted 14/12/2008 - 20:17
does anyone with the battery grip for k200 know if one of the pins is suppose to be shorter than the rest please.
still having probs just said batteries are dead, so put in body and there perfectly fine (full)
just keep snapping,
Posted 14/12/2008 - 20:27
Take a shot of it, and put it on here so we can see.
Tel,
Posted 14/12/2008 - 20:53
i cant work out how to post pics on here sorry tel must be a dumb a##
just keep snapping,
Posted 14/12/2008 - 21:22
Look in the threads under Competitions and you will see a Sticky desribing how to post images here. Please don't confuse the Competitions Gallery with unrelated images.
Posted 14/12/2008 - 21:51
I have a grip for my K20, one of the pins is shorter than the rest!...........I have no problem with batterys,but the on/off switch on mine doesn't work!......lol........couldn't be a***d to send it back as everything else functions!................Ken
Posted 14/12/2008 - 22:02
cheers beginner, yours must be on all the time then is that right.
And i know what you mean its just the hassel of sending it back plus cost but looks like i will have to.
just keep snapping,
Posted 14/12/2008 - 22:34
So, if the switch on the grip is turned to 'off', the shutter release on the grip will still fire the camera?I have no problem with batterys,but the on/off switch on mine doesn't work!
Dan
devon (honiton)
I open it then they last for ages, and there fine in the body.
