k200d battery grip
beginner
Posted 14/12/2008 - 23:08 Link
Yes it does Dan!......it must pull the power through from the camera end!......and the camera does use the one in the grip!..........Ken
beginner
Posted 14/12/2008 - 23:29 Link
Same one as mine!...........
scottthehat
Posted 15/12/2008 - 00:02 Link
cheers again beginner
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
geclinke
Posted 16/12/2008 - 14:09 Link
I've got the battery grip attached to my k200d, and if the camera switch isn't on, it ain't takin' a photo with the grip button.
Going into the power management menu on the camera, it shows the batteries at full tilt in the camera and grip. Perhaps it's a firmware issue? Are you using a Kx0d?
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Daniel Bridge
Posted 16/12/2008 - 15:10 Link
The camera body needs to be switched on - the on/off switch on the grip just controls whether the shutter release and other controls on the grip are acrive or not. The battery in the grip will still be used as appropriate whether the grip is switched on or not.
Dan
scottthehat
Posted 16/12/2008 - 17:39 Link
yeah dans right its only ment to work with the camera on
just keep snapping,
scottthehat
Posted 16/12/2008 - 20:53 Link
