K10d af not working
You'll find the address on the Pentax UK website: http://www.pentax.co.uk/en/service-centre.html
I was hoping somebody would have had the same problem and knew a fix SRS said at the time they simply upgraded the firmware, but as far as i am aware it came back with the same firmware version as when it went to them. i have read about solving AF problems using debug mode but they were concerning AF not focusing properly ,I wondered if anybody had an idea for a DIY fix?
ismaelg
Site Supporter
ismaelg's Avatar
First step is to make sure the contacts are clean. Carefully clean the contacts in the body mount (and in the lens as well to make sure). You can use an eraser or a very fine grit sandpaper GENTLY. Check to see if any of the contacts look damaged or different.
Hope this helps.
Thanks,
Yesterday, 02:27 PM #3
JimJohnson
Site Supporter
JimJohnson's Avatar
In addition to cleaning the contact points, make sure all the screws for your body's mounting flange are snug. When mounting a lens, hold in the release button, turn the lens all the way into the mount, release the lens release button and turn the lens backwards in the mount until the lock clicks. If you still do not have full lens functioning, try slowly rocking the lens slightly clockwise / counter-clockwise and watch to see if you get a connection.
webba
New Member
Posts: 2 | Likes: 0
Original Poster
Well I combined the advice given by both ismaelg and Jim Johnson and it worked I honestly cant say which as I did them both at the same time. but I would like to thank both of you
Any thoughts on best way to clean contacts?
I don't think I would take sandpaper of any gauge anywhere near my K10.
I had seen about using erasers (apparently Canon used to recommend this approach but don't now) but also a lot of warnings about using them.
What most seemed to recommend was isopropyl alcohol on a barely damp microfibre cloth or cotton bud.
Then you have a second problem
regards
Bernard
Take care.
Chris R.
I. El. (Eng). (Rtd).
Please be warned, what ever else you do, never ever use sand paper on electrical contacts, be it on your camera or any other item/appliance.
Take care.
What he said!
Pentax K10d, *istDL, Kit lens ( 18-55mm ), 50mm f1.7 lens, Tamron 70-300mm lens, Prinzflex 70-162 manual lens, Various old flashes.
webba
Member
