K-x owners please help - "shake reduction" issue
sazanovich
Posted 09/01/2011 - 18:57 Link
Hi folks, I've bought a Pentax K-x over the Christmas break (the used one on ebay) and got a bit frustrated with it. In all image shooting modes, the "shake reduction" option stays OFF and I cannot figure out how to switch it ON! I know it sounds silly. I can see the "shake reduction" item in the INFO menu, it is shown as "OFF", but it is gray and I just cannot select it to switch it ON! However, when I set the mode selector knob onto "movie" then "shake reduction" is shown as ON. Any ideas what could it be? Thanks a lot in advance.
GDN
Posted 09/01/2011 - 19:24 Link
I haven't got a K-x but assume that the shake reduction on/off is situated within the menu system. On the K5 its on the 4th menu at the bottom.
Be aware that the camera automatically switches Shake Reduction off in the following situations: using the self-timer, remote control shooting, shooting in B mode or during HDR Capture.
Hope this helps.
Gary
Pentax K3
My Flickr
flossie
Posted 09/01/2011 - 19:51 Link
By the sound of it, its most likely to be in remote control mode, as you can still shoot with the normal button, and this mode can be turned on/off from the back panel without going into any menus...
sazanovich
Posted 09/01/2011 - 20:22 Link
Hope this helps.
Hi Gary, thank you very much - it helped indeed! I was convinced I had checked all the options, and I've read in the manual those limitations on "shake reduction" when in different shooting settings; however when I read in your post about HDR I realised I do not remember how it is set now. I've just had a look again and - ooohhhh yes - the HDR was OFF, that was not the issue, but the shooting mode was on "remote control" indeed!!! I do not know for what reason the previous owned had put it on. But now I got it sorted!!!
And thank you flossie very much as well - that was exactly what you said "Nice shot"
Cheers,
Igor
sazanovich
Posted 09/01/2011 - 20:23 Link
THANKS EVERYBODY!!!
I GOT IT SORTED NOW!
Cheers,
Igor
Mike-P
Posted 09/01/2011 - 20:27 Link
First rule of fight club ... sorry, photography.
If you buy a used camera always reset it to default settings before anything else.
Edited by Mike-P: 09/01/2011 - 20:28
sazanovich
Posted 09/01/2011 - 20:35 Link
Good point, Mike, thanks. I need to do it indeed.
i-Berg
Posted 10/01/2011 - 04:57 Link
A good purchase, nice camera
Did you check to ensure it has current firmware installed while you're at it?
sazanovich
Posted 10/01/2011 - 20:47 Link
Hi i-Berg,
No I haven't yet. Still learning it
katiem111
Posted 16/01/2011 - 17:59 Link
new firmware update released on the 13th, just updated mine now to v 1.02
S**t happens, but usually before I can get my camera out
