K-r LCD Problem.
Posted 24/08/2013 - 09:45
I'd start with a reset to factory settings just in case you've inadvertently disabled the display somehow (although I can't think how).
Posted 24/08/2013 - 12:57
I can't even see anything on the screen, so I don't really think I can reset the camera to factory settings. Thanks for the suggestion anyway
Kr - DA 35mm
Posted 24/08/2013 - 13:04
What happens when you press the INFO key?
Posted 24/08/2013 - 14:44
Press it 2 times and it will turn completely black (much like when it is switched off).
Kr - DA 35mm
Posted 24/08/2013 - 16:40
But what happens when you press it once? Can you see stuff on the screen?
Posted 24/08/2013 - 17:12
Nope, nothing appears on the screen.
Well, it seems that no one in the forum have an idea how to deal with this. Thought that this is only a minor problem but it seems the other way around. No other choice now but I have to send it to the service centre for repair. Thanks anyway to those who tried to help, it was much appreciated
Kr - DA 35mm
Posted 24/08/2013 - 17:18
Have you tried taking the battery out for a while, maybe overnight?
What happens if you use live view? If still blank it would indicate there is a problem with the screen itself, especially if the camera takes shots no problem.
Try switching to live view and see if it comes on or take out the battery for a while.
Posted 24/08/2013 - 18:14
Hmm, haven't tried this one yet, maybe I could put try this tonight. Thanks for the suggestion Have you tried taking the battery out for a while, maybe overnight?
When I switch to the live view, I can hear the mirror change sound, so I assume that the live view mode works, just that the screen shows nothing (black/blank). So most probably the problem is with the screen right?
Kr - DA 35mm
Sheffield & Malaysia
Sorry if I am posting this in the wrong section but I want to ask something regarding my camera. The LCD on my K-r suddenly has gone black (not showing anything), the camera still works fine, it can capture pictures and everything else, just the LCD is not working. I think this is just a minor problem, so if someone has any idea what to do with it or if I need to send it to repair, where do I need to send it to?
Cheers! =)
