K-r Firmware problem, assistance, please.
Posted 20/11/2011 - 08:55
geordie01 wrote:
Sorry, think I need to go to Specsavers. ChrisR wrote:
Take care.
Because it is K110Dgeordie01 wrote:
I thought that main reason to update was to use HDXC cards but i have not got any so i did not bother but i did update the firmware on a k110d to use cards larger than 2gb that was worth doing unless i am missing something. i will wait until vr 1,2 for the kr and decide then.
Why did you have to update the K10d to take above 2gb, the K10d, was SDHC ready, I have one of the early K10d's, takes SDHC (ie above 2gb) no problem. No update of firmware.I thought that main reason to update was to use HDXC cards but i have not got any so i did not bother but i did update the firmware on a k110d to use cards larger than 2gb that was worth doing unless i am missing something. i will wait until vr 1,2 for the kr and decide then.
Take care.
Take care.
Chris R.
I. El. (Eng). (Rtd).
Posted 15/12/2011 - 21:53
karma mechanic wrote:
When you unzip the downloaded file you should get a readme.txt file and another one called Fwdc209b.bin - is that part working ok?
The Fwdc209b.bin file is the one that you put on the SD card for the camera to load from. You don't put it in a directory, you put it on the card (i.e. the root directory).
Then you power up as in steps 4 and 5:
4. Turn the camera power on while pressing the MENU button.
5. "NOW LOADING" appears in the LCD monitor, and will change to the
"PROGRAM UPDATE". At the bottom of the LCD monitor,
CURRENT VERSION 1.00/1.01/1.10
UPDATE VERSION 1.11
will be displayed.
So at what point does it depart from that sequence?
Downloads : Firmware UpdateWhen you unzip the downloaded file you should get a readme.txt file and another one called Fwdc209b.bin - is that part working ok?
UPDATE VERSION 1.11
will be displayed.
Thank you for using a PENTAX K-r digital camera.
PENTAX wishes to announce the release of Firmware Update Software Version 1.11 for K-r.
Firmware in this document is the software that runs inside digital cameras.
Changes to V1.11
•Corrected method for obtain GPS data when developing RAW images that is contain GPS data on Version 1.10
*If the collaboration model is updated with this software, original start-up screen is deleted and it is changed to standard start-up screen.
*If you have already updated to Version1.10, we are very sorry for this inconvenience. Please update to Version 1.11.
Changes to V1.10
•Correspond to GPS unit [O-GPS1]
Changes to V1.01
•Compatible with SDXC memory card.
* Transfer rate is not compatible with UHS speed class.
•All ISO sensitivity setting can be used on Bulb mode.
•Improved functional sequence for Contrast AF and improved total speed until in focus.
Caution
•Only K-r users are permitted to download the firmware update.
PENTAX Firmware Update Software for K-r
Name
Registered name
kr_e111w.exe (For Windows 9,874 Kbytes) , kr_e111m.zip (For Mac 9,798 Kbytes)
Applied product
K-r
To check the version number, turn your camera on while holding down the MENU button.
The version number will appear in the center of the LCD screen.
Updated firmware file
For Windows : LHA self-extract file, For mac : zip type
Release date
2011/07/14
Copy right
PENTAX RICOH IMAGING COMPANY, LTD.
Preparation of update
•Blank, formatted SD/SDHC card (32MB or more)
•USB cable I-USB7
If you are copying the firmware update file to the SD/SDHC card by connecting the camera directly to your computer.
•SD/SDHC card reader or a computer with a SD/SDHC card slot.
If you are copying the firmware update file to the SD/SDHC card using a memory card reader / writer.
•Fully charged battery (D-LI109)
Download the updated firmware file
•For Windows : kr_e111w.exe --- 9,874 Kbytes, LHA type, self-extracting files
•For Macintosh : kr_e111m.zip --- 9,798 Kbytes, zip type
Extract downloaded file
The following two files will be generated once the downloaded file is extracted by double-clicking.
•readme.txt: The text file that explained update procedure in details.
•Fwdc209b.bin: This is the updated firmware.
Copy fwdc209b.bin file to SD card
After formatting the SD/SDHC card, copy the fwdc209b.bin file to the route directory of the SD/SDHC card.
Update Firmware
Please read the readme.txt file attached to the firmware update before updating the firmware.
1.This software may only be used by users who own the K-r.
2.This software is covered by a software license agreement. Please read the software license agreement before downloading the software.
3.You will have agreed with this software license agreement when the download starts.
PENTAX Firmware Update Software for K-r Software License Agreement
The customer (hereinafter "the user") shall verify the following items below related to the use of the licensed software supplied to the user by PENTAX RICOH IMAGING COMPANY, LTD. (hereinafter "PENTAX RICOH IMAGING").
The download starts when you press "I agree. Start download." on this software license agreement.
1.Definition of terms ◦Licensed software: "Licensed software" means the captioned program in a format that the user can download from the PENTAX website or from a site empowered by PENTAX.
◦Use : "Use" means the user downloading and retrieving the licensed software from the PENTAX website or from a site empowered by PENTAX.
◦Designated machine: "Designated machine" means the single computer system set up in order for the user
This was taken off the pentaz web site.
Cheerss
Dave:
Shanghai
Now all I need to do is learn how to work the K-r 'thingy'. Does anyone know how to ....... Kind regards. Gedski.
Welcome to Pentax and Pentax User Ged. !
