K mount lenses - HELP!
Posted 04/11/2006 - 18:45
Hi and welcome to the forum.
THis question has been raised and covered a few times, basicaly all Pentax lenses will work (with restrictions) on all Pentax DSLR's.
This thread is the most recent explanation of what each version of the lenses will do on Pentax DSL's.
https://www.pentaxuser.com/forum/viewtopic.php?t=2970&highlight=lens+compatability
Hope this helps you.
Brian.
Brian.
Posted 05/11/2006 - 19:23
Many thanks for your quick reply - vry helpful.
Posted 06/11/2006 - 01:37
all my lenses are SMC apart from the 18~55 which came with the *istdl and you can switch the digital camera to use an aprature ring on m series lenses
you get more control with A series lenses as i have me supers and super As as well as *ist digital models
Posted 06/11/2006 - 16:04
By setting the camera to accept a lens in other than A setting, and using either the green button or the meter in Manual, you effectively have an apeture priority lens. Just another step to the process, no biggie!
Posted 14/11/2006 - 05:51
Your kit lens isn't an SMC. My ist-DL came with an SMC lens. I did the same thing tho. I set my DL to use an apperature ring and use all of my lenses that I had for my ME-Super. Works great but a split ring focus would be much nicer. And metering is no where as easy as the ME
Pentax ist-DL
Pentax ME-super with some goodies
Canon AE-1
Kodak P-850 12x optical rocks my point and shoot world
Canon AE-1
Posted 14/11/2006 - 10:56
If your 18-55mm lens has the Pentax name on it, it has the SMC coating. If its a Sigma of course, or any other third party lens it can't have the SMC coating.
20 years
Can anybody recommend a Pentax SLR which will have a compatibale fitting?
