K-5 Sudden Glitch Seeking Help & Advice
Posted 27/02/2012 - 03:40
Did you try to fix it by taking the battery out? Several people have reported that their K5 locks up at occasion; the circumstances vary.
If it does not solve the problem, time for (warranty?) repair. If it solves it, just keep an eye on it.
I'm lucky, mine did not lock up (yet).
Posted 27/02/2012 - 07:47
If it's reproducible, is it also reproducible with another SD card?
Posted 27/02/2012 - 08:51
Please only post in one section, the other thread has been closed to avoid confusion.
Posted 27/02/2012 - 12:29
Apologies John
Thanks for the comments.
I have since removed battery and replaced, also removed and replaced the sd card.
Results were ok. I was able to browse through 50+ shots and camera stayed on
I am a little worried if the camera is developing a fault so early in its life, or if it's the sd card faulty I would be disappointed as I purchased a sandisk extreme pro for ruggedness and reliability, that too is only approx 5mth old and had.
When next out shooting I will use a different card to see if I have the same problems.
Many thanks again for your help and advice.
Rob
Rob
Posted 27/02/2012 - 14:44
If it's any consolation - my K-x did it twice in it's first year and never again since
let the education continue
Posted 27/02/2012 - 14:53
Just a thought. Had you taken the card out of the camera (since it was last formatted) and put it in a computer?
It is possible that the computer subtly changed one of the files so that your camera got confused.
As I say, only a theory.
Posted 27/02/2012 - 16:15
The card I mainly use is a sandisk 16gb extreme pro. Only had approx 700 photos processed through it in stages.
After every day's shoot I upload the photos to my pc and click the icon "delete" once completed.
Then when I replace the card into the camera I always select "format card" before I reuse, as this was advice given to me from a fellow photographer.
Al Jones2402
I would like to ask the question if any K-5 owners have experienced a similar fault as described below?
Turned on camera and pressed playback button to view photos I had taken the other day and started to browse using arrows keys when suddenly, several frames in the camera appears to turn off?
What does remain is top screen(not back lit) displaying battery full logo only, and main lcd screen blank but lightly backlit?
I Turned the camera off, started the same process and the same happened again?
Camera had a fully charged battery and had not been used all day.
Camera owned new since november 2011 and performed with no problems until now.
Any feedback and advice would be appreciated.
