K5 SD Card ejection stiff?
Posted 27/02/2012 - 09:30 Link
Can anyone advise on whether it is 'normal' for the ejection mechanism for SDHC cards on the K5 to be stiff?
On my K20 when i pushed the card in it "springs" it out slightly then I grip it and pull out smoothly. On the K5 the push in and spring out works the same, but when I grip it there is considerably more pull required (and sometime a bit of a wiggle) to take the card out, some times it feels as though it is not going to come out. I have tried with 3 cards, all the same.
Any comments/advice greatly appreciated
Posted 27/02/2012 - 09:34 Link
It's normal
There's a technique to ejecting with the K7 & K5 - you push in with a fingernail and slide your finger off the card quickly. (So rather than pushing like a ball point, you're making an "L" shape movement) This lets the spring in the SD card slot eject the card out more fully.
It seems to vary a bit depending on the card as well.
ChrisA
Posted 27/02/2012 - 09:36 Link
It's like that on mine too. IMO the slidey card door and the ease of getting the cards in and out is a real design weakness of the K-5 compared with the 10/20.
Shame, since more or less everything else is so much better.
MartynUK
Posted 27/02/2012 - 09:54 Link
Just to add that you also need to be careful INSERTING the SD card as well!
I'm not sure how the card is 'gripped' within the slot, but I recently inserted one and a small piece of the plastic from the card got snapped off and lodged into the bottom of the SD card slot. Foolishly, I thought I'd try and get it out myself - which resulted in a heafty repair bill !!
montyaus
Posted 27/02/2012 - 09:59 Link
The card ejection is a matter of practise,it becomes second nature if you use your thumb nail and middle finger nail,it is probably the sealing of the card, it feels like a rubber seal makes it a bit stiff.
Some zooms
https://pentaxphotogallery.com/artists/jack" target="_blank">http://c759846.r46.cf2.rackcdn.com/img/black_link.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Posted 27/02/2012 - 10:12 Link
Within 30 minutes I have enough answers to satisfy me that I haven't got a faulty model and some additional advice on inserting too! Thank you all!
I love this forum
Edited by LennyBloke: 27/02/2012 - 10:12
gregmoll
Posted 27/02/2012 - 15:10 Link
My SD cards were also very sticky, on one of the other forums there was a post about sanding down (only a fraction) the long thin sides of the card, which I did.
Now if I'm not careful when removing the cards they jump up to meter in the air.
Greg
gregmoll
Posted 27/02/2012 - 15:35 Link
Here is the instruction video link
greg
Posted 27/02/2012 - 15:42 Link
The K-5 is smaller than the K20D and as a consequence there isn't as much room to get fingers in to grasp the SD card. I use two opposing ringernails to make this easier, but it's one design aspect that is actually better on the K20D.
sterretje
Posted 27/02/2012 - 17:25 Link
Coming from the K10D, I was worried about it when I bought the K5 (as the complaint was the same for the K7).
It's indeed a bit tighter but I hardly experience it as barely swap cards and upload is via the cable.
judderman62
Posted 27/02/2012 - 20:21 Link
it is a little bit on mine but not too bad - far worse on my K200D so the K5 was actually a step up so to speak
Frogherder
Posted 28/02/2012 - 00:42 Link
I'll second that. With fingers like popeye I struggle to the degree I now carry a set of plastic tweezers in my bag
Bernard
Edited by Frogherder: 28/02/2012 - 00:48
Posted 28/02/2012 - 07:51 Link
I watched the video that Greg linked to, I didn't expect SD cards to be so different in size! Not sure if I'm brave enough to sand the cards down though
Thanks Greg
gregmoll
Posted 28/02/2012 - 08:21 Link
Hi Lennie,
I sanded down nine cards with no problem, one only has to take off a very small amount. One thing to watch out for is that the write lock slider can move to the lock position whilst sanding, caught me out.
Greg
Posted 28/02/2012 - 08:35 Link
Thanks Greg - I'll give it a try on one of my smaller capacity cards at the weekend - Assuming that works out it'll give me the confidence to do the others!
