K-5 continuous shooting problem
Posted 11/07/2011 - 13:17
Yes, a couple of times now.
I too was shooting in continuous and the camera behaviour was the same with the AF points remaining lit and everything frozen.
Cured it the way you did, by taking the battery out.
Was using Pentax battery (on 3 segments) & Sandisk Extreme III 8GB card.
I was unfazed the second time but would be a bit cross if it happenend on a crucial shot.
Regards,
Regards,
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 11/07/2011 - 13:27
Are you sure it wasn't just that the buffer was full?
Posted 11/07/2011 - 13:31
I don't think so John, I'd only taken 4 images from when the aircraft started to taxi before it took off. This happened about halfway through the flying display and I had no problems beforehand.
Posted 11/07/2011 - 15:37
Blythman wrote:
Both Barrie and I suffered this about 3 weeks ago, and we mentioned it on here. He was at Beamish and I was at The Farnes
Any ideas as to what might have caused it?
Posted 11/07/2011 - 16:05 - Helpful Comment
The camera loacking up is mentioned in every DSLR manual. Build up of static charge or something like that. The cure is to remove the battery for a while and then start again. If this works, the manual says there is no need for a repair.
Avoiding strong magnetic fields is advised, so I suppose keeping the camera on an unshielded speaker would be the sort of thing to watch for.
Posted 11/07/2011 - 16:06
Thanks Alan & John, fingers crossed it won't happen to me again.
Posted 11/07/2011 - 16:38
Last time happend to me single shot middle of field. Maybe myserious lay lines that affect k5s or maybe just another fault seems to happen to a lot of people
Essex
I was using an Inov8 battery in the body which I had fully charged the night before and an Integral 16gb Class 10 SDHC Card.
Has anyone else experienced this problem before? Was it either the card or the battery that might have caused this?
