K-3 Vs. K-5iis
Smeggy beware!
When something goes wrong in the circus, they send clowns into the arena to distract the audience.
Interesting...
Concert photography
I would have to agree 100% with you on this David. The K3 was never going to outdo a K5 for high ISO noise levels.
Smeggy beware!
I already compared the noise levels between the K-5 and the K-3 at ISO6400 and ISO51200. I posted the pics on on the "K-3 studio test shots now on Imaging Resource" thread. I'll repost them here for reference....
Imported into Lightroom 4.2 and applied my standard NR settings for ISO52100 to each. I have to say the K-5 beats the K-3 hands down. And it's not just colour noise. the colour noise setting in LR4.2 on these 21/100. Even wacking it up to 100/100 on the k3 version, still left loads more luminance noise than the K-5 version.
The next step was to increase the luminance setting ( which is on 47/100 for these examples ) so that the K-3's luminance noise levels roughly equalled that of the K-5. Somewhere around 70/100 did the trick but left that hideous 69th generation VHS copy smear that high NR gives.
So far I conclude that the K-3's ISO performance has suffered because of the marketing need to keep up with the MegaPixel race. I hate this damn MP race, and would rather have better IQ than more MP. However before making a solid conclusion I aim to repeat his test at mid range ISO values, i.e ISO6400. I wager it will be the same proportional difference given Dynamic range/ISO specs are pretty linear. i.e you roughly lose 1 stop of dynamic range for 1 stop of ISO
Here's the full image and 100% pixel peep versions for each ( click on pics to avoid annoying dinosaur 800px restriction )
K3 ISO51200 - full pic
K5 ISO51200 - full pic
K3 ISO51200 - 100% pixel peep
K5 ISO51200 - 100% pixel peep
Imported into Lightroom 4.2 and applied my standard NR settings for ISO6400 to each. I have to say again the K-5 beats the K-3 hands down.
Luminance NR 20/100
Colour NR 16/100
K3 ISO6400 - full pic
K5 ISO6400 - full pic
K3 ISO6400 - 100% pixel peep
K5 ISO6400 - 100% pixel peep
K-3 v. K-5 ISO51200 Comparuison here
Cheers Jules...
Does the K-3 come with a new dedicated version of PDCU and what are images like when processed through that? I'd like to see.
Is there any chance that firmware updates will improve this apparent downgrade in high ASA quality on the K-3 or is it inherent to the high pixel smaller sensor? Certainly the lower ASA images look to be an improvement over the K-5 shots.
I wont jump to conclusions just yet, but maybe i'll just keep my wallet in my pocket for another year and wait to see what comes along.
As for me, all I know is that I know nothing.
This will probably be addressed in a future LR upgrade
Comparing in LR without having the K3 profile isn't comparing like-for-like AFAIK
Seem to remember reading somewhere that Adobe create a base profile for the noise floor of the camera, detailing the 'quality' of the noise. And then the controls work on top of that.
So with no K3 profile available you've got 'really raw' settings.
Perhaps if you took the K5 DNG into a hex editor and changed any "K5" strings to "K3" you'd get a more representative comparison?
I've been working with JPEG files and they are by definition already updated for the respective cameras.
davidstorm
Plus Member
Sheffield, England
Before I tell you the results, I will add a few 'caveats':
- Tiny focussing errors can produce misleading results as I found tonight - especially when viewing at 100% or more
- Auto WB on both cameras was pretty variable, hence I have adjusted the WB on both images to make it as similar as possible. Overall the K-3 did the best to reproduce accurate WB under difficult light, but neither was perfect.
- Even trying to be as consistent as possible there are detectable differences in the levels and colours after adjustment of these, also the Forum is applying slightly more compression to the image you see here from the K-3 as it is larger in overall proportions when scaled to 100%; this has the effect of slightly lessening the quality of the K-3 image you see here compared to what I see on my PC screen
My conclusions are as follows:
ISO 100: K-3 is a clear winner due to clarity from the additional resolution and a nicer overall picture quality (both are superb though)
ISO 1600: Boy it's close! K-3 just shades it for me - greater clarity, still very little noise in both images. What noise is there is unobtrusive and could easily be cleaned up. The noise is different in character on the two cameras, but not very different in actual noise levels
ISO 3200: The K-5iis blows the K-3 away completely. If you need to shoot at 3200 ISO the K-5iis is a better camera. This may change with firmware improvements to the K-3 over time. I am running latest firmware on the K-5iis.
See below the ISO 1600 images, both cropped at 100%. I'm not going to post the ISO 100 and ISO 3200 as I did not manage to get two that are comparable enough on the focussing so you will have to take my word for the above conclusions! Also, bear in mind that I have not applied any post processing noise reduction or sharpening to these images.
K-3
K-5iis
I thin I may have lit the blue touch-paper on this one!! Your comments and observations please!
