K-3 shutter Count...
Posted 13/06/2018 - 02:36
Have you updated the firmware during all of this?
I believe they never found the cause of the problem, but did write a check into the firmware that would stop it if it was detected happening again.
(not the ideal solution, but better than nothing)
You're nearing 100,000, so getting up there. I believe the mechanism is rated at twice that, but as always anything could fail before that particular component does.
In terms of resale, you can pass a point where it's just as worthwhile hanging onto it and running it into the ground.
In terms of sheer capability, the K-3 is still relevant today. In a lot of ways Pentax haven't released anything dramatically better since. There are mkii versions of both the K-3 and K-1, but the K-3 is still more than capable. Many would argue so is the K-5 from before it as well, but I think the K-3 places you in the modern Pentax world still, despite being quite old now.
Remember the K-3 and K-1 have quite different focuses. Ha photography pun there... The K-3 has a large buffer and a fast burst rate, making it the most suitable Pentax for sports/birding, where as the K-1 is FF and more focused on image quality/lower light use. I think they complement each other more than they compete.
Posted 13/06/2018 - 07:55
Plenty of life in the K3 yet in my view....
Stuart..
Stuart..
Posted 13/06/2018 - 21:38
Not sure of my shutter count Judith Ann, but I've had my K-3 for about 5 years now and I've experienced the crazy shutter flapping a few times. I've come to the conclusion it is related to low battery power, it behaves itself again when the battery is replaced. I would think yours has plenty of life yet, the shutters are rated at least for 200,000 shots.
I'm not looking to upgrade my K-3 or K-5iis, I don't do commercial photography, I don't display in galleries or exhibitions, it's just for fun. I don't think I'd get any more fun shooting with a K-1, plus I would have to spend a lot of money on new lenses.
Posted 13/06/2018 - 21:46
You wouldn't get tired arms either carrying full frame equipment....lol
Stuart..
Stuart..
Posted 15/06/2018 - 01:21
My K3ii is a baby by comparison at 7662 and the only time I've had a shutter fright was when using a cable remote with the camera set to 'continuous burst'. 1st click, off it went, 2nd click, then frantic clicks and presses of shutter release failed to stop it ! I had to turn it off manually at the switch. I have no desire to buy a K1 because the K3 is a super camera. (ignore the video - I have no use for it anyway).
Posted 15/06/2018 - 04:34
Thank you all for your input.... I am still planning to use my K3 for a while.... but I do think I will eventually go full frame!
I updated this week making sure I have the latest and greatest. I just bought the 70 -200 lens, it is a big brute, with great work ethics... sharp, as a pin! LOL
Ja
Ja
Posted 16/06/2018 - 21:17
Just checked my K-3 which I bought in October 2014. It's at 22,696 so has a way to go yet. Fingers crossed: I've never had the problem mentioned. It has worked flawlessly since I have had it. Hopefully, that's not its death knell.
K.
K.
Canada;Alberta
It is Your photo's metadata indicates the following:
Camera PENTAX K-3
Shutter Count 94,689
Manufacture Date 2013:09:30
I am interested in other K-3 owners..and or other models too...What is your shutter count! You can simply upload a Jpeg photo on this site. it will give you the info.
JA
Read more at: https://www.pentaxforums.com/pages/check-shutter-count-exif.html#ixzz5IGMduRyJ
