K-3 date issue
Posted 04/02/2016 - 18:17
The capacitor that stores the power for the memory when the battery is replaced and removed will be knackered.it happened my k30 as it was out of warranty i did not bother and just ignore unless I need the exif to be right then I just input the date time etc and it is fine untill I replace the battery.
Posted 04/02/2016 - 19:12
Would that be the Flux capacitor?The capacitor that stores the power for the memory when the battery is replaced and removed will be knackered.it happened my k30 as it was out of warranty i did not bother and just ignore unless I need the exif to be right then I just input the date time etc and it is fine untill I replace the battery.
Maybe Doc and Marti could help you out here. 😉
Posted 04/02/2016 - 20:51
Ahhh, OK. Luckily mine is still within the warranty. Thanks folks, K.
Hertfordshire,
mostly.
Does anyone else have this problem, or should I be getting someone to look at it?
Thanks, Kris.
