K-1 in Cornwall
Posted 27/10/2017 - 21:36
should have gone down the road a bit more and had a rattler or 2 that will make the k1 more faverable
Posted 28/10/2017 - 06:56
I use mine for Jets in the Mach Loop, Flying insects and bugs / wildlife of all sorts, its a good all rounder.
Chris
Posted 28/10/2017 - 09:33
Maybe I just need more time to get used to it, I'm probably just not in the right frame of mind tbh.
Forgot to add that when we got back we found that our son had switched off the fridge and freezer just before we left so arrived home to a bad smell, water all over the kitchen floor and rather a lot of spoiled food.
Posted 18/11/2017 - 05:26
Nowt wrong with any of them Mike but you know the future is mirrorless don't you? Maybe I just need more time to get used to it, I'm probably just not in the right frame of mind tbh.
K1 is a good tool no doubt though, it's more than the sum of it's parts just gets the job done, gotta love camera's like that, a classic!
Bad luck with the fridge mate, you just don't need it...
Cheers Jules...
Posted 18/11/2017 - 19:09
Maybe you could do plug into an unswitched socket - or even fit an unswitched cord outlet and wire it into that as then the fridge will never go off unless the mains system RCD trips or the supply to the house fails, as the latter is what I did.
Posted 18/11/2017 - 23:36
jeallen01 wrote:
What's wrong with a sticker above the plug saying "DO NOT SWITCH OFF"?
Maybe you could do plug into an unswitched socket - or even fit an unswitched cord outlet and wire it into that as then the fridge will never go off unless the mains system RCD trips or the supply to the house fails, as the latter is what I did.Forgot to add that when we got back we found that our son had switched off the fridge and freezer just before we left so arrived home to a bad smell, water all over the kitchen floor and rather a lot of spoiled food.
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 19/11/2017 - 08:56 - Helpful Comment
pgweber wrote:
[quote:3496ace15f="jeallen01"]What's wrong with a sticker above the plug saying "DO NOT SWITCH OFF"?
I don't know how Mike's son's brain works, but I would suspect that reading, understanding and then following written instructions like those may not be one of its most reliable aspects (read what Mike said in one of his earlier posts).
Posted 19/11/2017 - 22:02
Mike-P wrote:
It seems to be very much a landscapers camera and I'm not really into landscape.
Well I'll trade you for my K3ii of you like!It seems to be very much a landscapers camera and I'm not really into landscape.
These looks good, is that a drone in the second top left?
Hythe,
Hampshire UK
Nothing special but quite pleased with how the K-1 performed. Still not sure it's for me though.
Surfer at Harlyn Bay Padstone Cornwall by Mike.Pursey, on Flickr
Porthilly View Padstow Cornwall by Mike.Pursey, on Flickr
Constantine Bay Cornwall by Mike.Pursey, on Flickr
Seal Harlyn Bay Padstone Cornwall by Mike.Pursey, on Flickr
