K-01 Manual Focus Zoom Behaviour
Posted 24/09/2012 - 09:22
I hope you find that somethings set wrong... It will be a
disgrace if a camera without a viewfinder can't be used
properly without a viewfinder
Posted 24/09/2012 - 09:29
Well, to be fair this is an option that is ONLY available through a screen. I don't think any Pentax offers up to 6x magnification through the viewfinder (though I may be wrong!) Someone from over the pond has just confirmed their's does the same, so looks like a bug - although I work in IT and therefore feel pretty sure this will be regarded as a "feature" that helps with obscure composition
Tony
Tony
Posted 24/09/2012 - 09:46
They don't magnify through the viewfinder, but the green
hexagon and beep is available which ever since the days
of the MEF has been the most accurate way of focusing a
Pentax camera..... just nobody is interested enough to
suss out what is accurate and what isn't.
I've not used focus peaking, but would be very surprised
if it's as accurate.
The big problem with MF is the movement on the lens is too
coarse slightest touch is about 100mm
Posted 26/09/2012 - 20:04
TonyM wrote:
I have noticed that when I first use the OK button to zoom the screen for focussing in manual mode, it rather bizzarely uses the top left of the frame rather than the middle. It only does this with manual lenses Tony
Don't have this problem with mine, it goes straight to the bottom left corner, again only with manual lenses. Thanks for the tip on pressing green button to centre it Tony.I have noticed that when I first use the OK button to zoom the screen for focussing in manual mode, it rather bizzarely uses the top left of the frame rather than the middle. It only does this with manual lenses Tony
I did notice it only happened after I had gone into the settings and enabled aperture ring, also the screen to set focal length for SR only came on after enabling aperture ring. Does this mean if you have a manual focus lens with an 'A' setting you have to enable aperture ring to use SR?
As an aside, does anyone know why aperture ring disable is the default? Under what conditions with an appropriate lens would you want to disable it?
Haven't tried focus peaking yet, but I must admit the green hexagon and beep on my GX10 & istDL2 was really good with manual lenses.
On the plus side, I think the silver K01 with 50mm f1.7 attached looks really cool. Always thought the lens looked somehow wrong on the front of the GX10
ist*DL2, 18-55Mk1, DFA 100 f2.8 Macro, Samsung GX-10, 10-17,18-55,50-200, Sigma 10-20,100-300, 150-500 Tamron 18-200, Jessops 360AFDP
ME Super, MX, 2No. 50mm f1.7, MZ-10, 28-70 f4, 28mm f2.8, Samyang 500 & 800 f8 mirrors, Vivitar 2x TC, K-01, K-30
Posted 26/09/2012 - 20:33
Just been looking at the instruction manual, and the picture on page 101 shows the magnified image going to the bottom left after pressing the OK button. It then advises you can centre it with the green button.
So perhaps it really is a feature
Posted 26/09/2012 - 20:35
Vic
Someone on the States site confirmed their's goes to the top left hand corner, so there certainly seems to be a bug here (problem with first release of anything I suppose.) They had another workaround, which was to slide the focus switch to AF and then back to MF, after which the OK button will zoom the centre of the screen.
As for the "enable aperture ring" setting, this has been around donkeys years and I can't understand why on earth it's there either!! Why wouldn't you!
BTW, I have the red button customised to switch focus peaking on/off. That way it's easily available when I slap a manual lens on, or if I want to fine tune with quick shift. I also find it more accurate than the hexagon.
Tony
Tony
Posted 26/09/2012 - 22:14
Not quite! What you see on the bottom left is a box representing the whole display. The smaller box inside then shows the area that is being zoomed and you will see that in the manual it is in the centre of the image, not top left. So definitely a bug!! Must get round to reporting it so that it makes the next firmware upgrade
Posted 12/10/2012 - 21:02
Too late TonySo definitely a bug!! Must get round to reporting it so that it makes the next firmware upgrade
Apparently the new firmware does fix it
Posted 12/10/2012 - 21:21
Yep, installed it earlier and now the fly in the ointment has been removed!
Surrey
Tony
