ist D battery mystery.
Posted 10/02/2022 - 16:32 - Helpful Comment
My first digital slr was an ist Dl2 and that had its moments with batteries it would frequently show no power when the batteries were fully charged. From what I can gather from that range of cameras. the electronics were picky for want of a better word re batteries. My problems were also solved with Eneloop batteries so I can only assume that there is some sort of conflict between Energisers et al and the camera board. Hopefully this answer hasn't exacerbated your confusion
Michael
Michael
Posted 10/02/2022 - 16:56
Thanks for that. It certainly helps to know that someone else has had a similar experience.
S.
S.
Michael
Michael
Posted 10/02/2022 - 17:11
Just a thought - is there anywhere in the settings which allows the type of battery being fitted to be identified? On the K5 you can specify which batteries are fitted in the battery grip in set up
Michael
Michael
Posted 10/02/2022 - 19:33
I used to have similar problems with a K-x. Usually resolved by taking the batteries out and re-inserting them, sometimes more than once. Not very scientific I know, but the issue defied logic.
Posted 10/02/2022 - 21:41
I seem to recall reading on the US forum that the istD family of cameras have a problem seeing fully charged lithium batteries. A fully charged lithium battery is 1.8 volts which causes a problem with the istD. Some people suggest partially discharging the battery to below 1.5 volts. The Eneloop battery is a NiMH with a nominal voltage of 1.2 volts.
Details of various types of AA battery and their voltages can be found here:
https://www.batteryequivalents.com/aa-batteries-size-types-and-equivalents.html
Paul
Posted 10/02/2022 - 23:59
redbusa99 wrote:
Funily enough had similar with mine today with same Lithium batteries (which are proving hard to get at the shops) ,Switched off ,removed batteries, replaced batteries , switched on all working fine.
Re. possible shortages...AA Lithium are in short supply...many battery distributors are out of stock of the Lithium AA although they still have stock of the AAA for the moment.Funily enough had similar with mine today with same Lithium batteries (which are proving hard to get at the shops) ,Switched off ,removed batteries, replaced batteries , switched on all working fine.
I'm beginning to speculate this might have something to do with the Global Elites stocking their underground bunkers for what they see as an imminent global disaster. The Max Keiser show on RT earlier today, was quoting from a report by the head of Commodities Research at Goldman Sachs saying that there was a fundamental 'Molecule Crisis'...the worst they had seen in the 30 years they have been doing the job.
Whether it was in oil, gas, coal, copper, aluminium...apparently they just can't get what they need...massive shortages.
So...if you need any batteries , cards...general consumables and can get them, might be worth stocking up whilst you still can.
Posted 11/02/2022 - 01:46
Electric cars are the current fad -- Lord help us when they all need new batteries or we need to dispose of them. They need lithium for batteries. So perhaps those who can are stockpiling the stuff until the price explodes?
Posted 11/02/2022 - 10:23
Didn't the *ist D have the capacity to take 2CR5 batteries as well as AA? I did have the *ist D but can't remember the configuration. If it did it may be worth trying those if you have some spare.
Z-1p, K-1, P50
Posted 11/02/2022 - 11:28
All Pentax's DSLRs that use AA batteries are very finnicky with which type of batteries they work with but I never had any problems with lithiums in my K200D.
Posted 11/02/2022 - 12:27
I have had great success with Uniross hybrid rechargeables.
For the shots I took yesterday with my K50 I fitted an adaptor with 4 of these that had been sitting unused for 2 years and they were still OK.
Posted 11/02/2022 - 12:53
2 x CR-V3 according to DePressing Review
Z-1p, K-1, P50
After pondering a while I went and dug out four AA Eneloop batteries and fitted them. Lo and behold, the camera works great. OK, back to the Energisers. Put two into a torch and the torch blasted out full power, as it did with the other two. Now I discover that without any batteries fitted, the battery indicator doesn't show at all but, as mentioned, works fine and shows a full charge with the Eneloops. I'm confused. Anyone have any thoughts? (Not on my confusion, but on the batteries and camera):
