INITIAL SETTINGS REST TAMMY 28MM WONT WORK
Posted 10/10/2013 - 18:19 Link
I did an" initial reset"and a resEt in custom mode, on my K20D.My 50-200mm wr lens works fine but when I attach my Tamron 28mmf2.8 ,the camera does not ask me to manually input focal lengh and there is no response when I press my shutter button.
Any suggestions from the community is appreciated.
Nadeem
davidstorm
Posted 10/10/2013 - 18:24 Link
Try carefully cleaning the contacts on both the lens and the mount with a microfibre cloth and ispopropyl alcohol or similar.
bigdaddybucks
Posted 10/10/2013 - 18:33 Link
If it doesn't have the "A" setting on the lens you will probably need to go through the menu and and select Permit under the Using Aperture Ring setting. I think it's in the custom settings part.
Lee
Mike-P
Posted 10/10/2013 - 18:38 Link
Enable "Use aperture ring" option in the menus.
Presuming the Tamron is a manual lens ... you prob enabled the setting when doing a reset as it's off by default.
Mike-P
Posted 10/10/2013 - 18:39 Link
And Lee beat me to it while I was slowly typing in the dark
Posted 10/10/2013 - 19:35 Link
Cheers guys, problem solved.
bigdaddybucks
Posted 10/10/2013 - 21:32 Link
Was it what we said?
