Info on Pentax-A 70-210mm zoom please
Posted 05/03/2008 - 11:37
Where did you get the impression that this lens is a macro? I have never seen that suggested before. The max magnification is .25, so a macro it aint.
It has a fixed max aperture - f4 - at all focal lengths.
Many people consider this lens to be as good as, or even better than, the F 70-210, which itself is an excellent lens.
So if it's in good nick, it's a good buy. But it's not a macro.
Boz's site has the specs.
http://www.bdimitrov.de/kmp/lenses/zooms/long/A70-210f4.html
Posted 05/03/2008 - 11:45
You beat me too it George Where did you get the impression that this lens is a macro? I have never seen that suggested before. The max magnification is .25, so a macro it aint.
I was checking out a couple of sites trying to figure out the Macro thing and couldn't find anything :
Camera:|K-7|
Posted 05/03/2008 - 11:49
I have my eye on one these at the moment on E-bay, it has a day to run with no bids and is bundled with a bunch of other junk. Its sitting on 30bucks and would be a bargain if i can grab it.
Camera:|K-7|
Posted 05/03/2008 - 11:53
Generally, I only use two zooms, and it's one of them. I bought mine as part of a bundle, too. They quite often come with SFX bodies.Quote:
I have my eye on one these at the moment on E-bay, it has a day to run with no bids and is bundled with a bunch of other junk. Its sitting on 30bucks and would be a bargain if i can grab it. the F 70-210, which itself is an excellent lens.
Posted 05/03/2008 - 11:56
This one has a non functioning SFX body and 2 other lenses with it
Camera:|K-7|
Posted 05/03/2008 - 11:57
Bet one is an F 35-70.This one has a non functioning SFX body and 2 other lenses with it
Posted 05/03/2008 - 12:00
Close but no cigar its an F28-70
Camera:|K-7|
Posted 05/03/2008 - 12:01
Shucks.George Lazarette wrote:
Close but no cigar its an F28-70 Quote:
Posted 05/03/2008 - 12:13
Thanks for the info.
graham
Edit
See picture at Item number: 150221217217 on ebay
On the focusing ring it says "Macro" which I assumed means there is, apparently, a setting for Macro. Problem is that I cannot access it Where did you get the impression that this lens is a macro? I have never seen that suggested before. The max magnification is .25, so a macro it aint.
graham
Edit
Keep up the good work
Graham
I'll think of something someday.
Graham
Posted 05/03/2008 - 12:25
The smc Pentax-A 70-210mm 1:4 Macro has a macro setting at 70mm. It's not true macro. The max aperture is F4 all the way along the barrel.
It's a beautiful item. I had one. However, by modern standards it is rather long and heavy, and I don't think it's sharper than the much smaller and lighter DA 50-200mm. At least it wasn't when I compared them focused on a suject about three or four yards away.
~Pete
Posted 05/03/2008 - 12:27
Need to zoom out to 70mm to use the "Macro" focusing.
~Pete
Posted 05/03/2008 - 12:31
graham
Edit
It does say Macro and from what i can make out it goes down to 1.2 Thanks for the info.
graham
Edit
When you zoom it out to its limit (on some lenses i have seen) you twist it and jumps out to its macro position. I could be way off track here :
Camera:|K-7|
Posted 05/03/2008 - 12:37
To access the macro setting, you simply turn the focusing ring after zooming out to 70mm. Slightly more force than usual is needed to get it on to the green (macro) section, if I remember rightly.
~Pete
Posted 05/03/2008 - 13:00
By gosh I've done it Thanks again for the help.To access the macro setting, you simply turn the focusing ring after zooming out to 70mm. Slightly more force than usual is needed to get it on to the green (macro) section, if I remember rightly.
Graham
Graham
I presume that the aperture at full zoom is 5.6 (that much I gleaned from the web), but am I right?
Also, what is meant by "macro" in this instance? Is it 1:1, or some more dilute interpretation?
I like the one touch sliding/rotating zoom/focus and the inbuilt lens hood, but not the fact that the front of the lens rotates - no screw-on polarisers or grad filters there then.
It also makes up for the fact that I sold off all my old manual lenses a few years back - a decision I have regretted ever since.
Any help much appreciated.
Graham
Graham
