Incomplete Exif data problem: a question
Would this work on your Mac? - Simple EXIF Viewer for Mac OS X 2.7.1
For something more substantial there's Gimp.
Maybe Mac users will make some further suggestions.
Perhaps you can compare those that do work and those that dont to see if there is a pattern
This is the exif of one from your gallery (The ICM coloured pencils):
[Quote]Camera Maker: RICOH IMAGING COMPANY, LTD.
Camera Model: PENTAX K-S2
Lens: smc PENTAX-DA 50mm F1.8
Image Date: 2017-04-24 14:55:46 (no TZ)
Focal Length: 50.0mm (35mm equivalent: 75mm)
Aperture: ƒ/22.0
Exposure Time: 1.600 s
ISO equiv: 100
Exposure Bias: none
Metering Mode: Matrix
Exposure: shutter priority (semi-auto)
White Balance: Auto
Flash Fired: No (enforced)
Orientation: Normal
GPS Coordinate: undefined, undefined
Creator: R.SOUCIE
Copyright: R.SOUCIE
Software: Adobe Photoshop Lightroom 6.0 (Macintosh)
[/quote]The site exif has corrupted that one:
[quote="PU site exif"]Camera Make:
Camera Model: MPANY, LTD.
Date Taken: 2017-04-24 14:55:46
Exposure Program: Shutter priority
F-Stop: f/22
Aperture Value: f/8.9
Max Aperture Value: Undefined
ISO Speed Rating: 100
Focal Length: 50 mm
Lens: Undefined
Metering Mode: Pattern/Matrix
Exposure Time: 1.6 sec[/quote]Yet your orchids exif seems OK
Lens: smc PENTAX-DA 35mm F2.4 AL
Image Date: 2017-02-14 09:48:55 (no TZ)
Focal Length: 35.0mm (35mm equivalent: 52mm)
Aperture: ƒ/16.0
Exposure Time: 0.050 s (1/20)
ISO equiv: 6400
Exposure Bias: none
Exposure: aperture priority (semi-auto)
White Balance: Auto
Creator: R.SOUCIE
Copyright: R.SOUCIE
Date Taken: 2017-02-14 09:48:55
Exposure Program: Aperture priority
F-Stop: f/16
Aperture Value: f/8
ISO Speed Rating: 6400
Focal Length: 35 mm
Lens: Undefined
Exposure Time: 1/20 sec[/quote]Maybe you're worrying about something you can't do anything about!
Were they processed with different software at some stage? (I note they were finished with Lightroom.)
... And forget what I said earlier as that doesn't seem to be the problem after all !
Strange, but my last two B&W postings (today) and one of my recent orchid postings have indeed included camera make and model. I had not changed anything about the way I export and upload them over the course of all my PU postings So this was a huge surprise to me. But unless I am not understanding JAK and pschlute, acquiring an EXIF viewer browser add on is not going to help the people using the site, who will not see the complete EXIF data if THEY don't also have such an add on. As for me, I can assure you that 99% of the images in my gallery leave off the camera make and model, and the exceptions noted by you and me are indeed exceptions. Finally, let me add that I almost always use only Lightroom to process my photos. Then I export them to my desktop and from there import them into PU. There are a small handful that first passed through Adobe Elements. I am most grateful for your responses to my question and I hope we can continue trying to find out why (apparently) PU is sometimes the "culprit" --or at the very least is inconsistent---and specifically, what the heck this TIFF business is all about. I also can tell you other people have exactly the same problem, as I can see for myself when I open their EXIF data on PU.
PU's exif extractor does seem to be a law unto itself and could do with a bit of investigating by the site developers.
As to David's query, the matter is explained (for better or worse) on DPR here.
David.
I need to look at the EXIF in detail and work out what it does mean, but I wonder whether or not it's simply referring to set and actual apertures on variable aperture zoom lenses.
Given that is a mathematical relationship it implies they are one and the same. Perhaps John can investigate why the difference noted in the PU exif extraction with the site developers. Having said that, other exif viewers also show differences so the site may be using data extracted by someone else's exif program.
FWIW the EUP book goes on to show a table of English F numbers and Continental F numbers which differ slightly Eg. English f/8 = Continental f/9. But given the book dates from 1940 I don't think that's anything to do with Brexit!
I can understand the thinking that an aperture could be defined as a physical measurement of the hole in the lens, as one might also say a window aperture is its measured size. Whereas an f stop is understandably the relationship between the diameter of the hole in the lens and the focal length of the lens which is fixed.
As David suggests, maybe variable aperture zoom lenses need an extra variable in the equation for the camera to ascertain a correct f number to use which wouldn't have been required in the days before zoom lenses and AE cameras.
Think of an uncoated and a multicoated lens. The lenses may well have the same physical aperture and the same nominal f/stop, but the muticoated lens will transmit a lot more light and therefore have a different T/stop value. The depth of field will still be determined by the f/stop.
Uncoated glass loses quite a bit of light, about 5% per surface. Multicoating takes that down to 0.1 - 0.2 per cent per surface, so a very dramatic difference. This was originally noticed when very old uncoated lenses that acquired a natural "bloom" had less flare than a new lens.
I never ever export PU-destined TIFFs---only JPEGs-- so this is not an issue. (But look at my first post to see why I brought up TIFFs in the first place.
It is entirely possible that me and several other PU users are presenting jpegs to PU with the Exif data somehow configured differently from all the other PU members. Nevertheless, I conclude that the PU Exif needs to be repaired or replaced, because I am not the only person with this problem. The bottom line is: if an independent Exif reader unfailingly produces ALL the correct data, why can't PU's Exif reader?
9 years
All the best,
hocusfocus
Now for the discovery I made the other day. I opened a JPEG image on my desktop in the Preview App of my IMac computer. Then I went to Tools>Open Inspector>General Information>More Info, where I found these categories: General, Exif, IPTC and TIFF. In the Exif category, I found ALL my Exif data except it may or may not show the lens used. But it contains no information on camera make and camera model. I then hit TIFF, and lo and behold, there was my camera make and model completely and accurately revealed!!
My question to all you experts out there: what is going on here? What am I to make of finding my Exif data (at least in my Preview App) split between Exif category and TIFF category?
Maybe the answer to this question may lead to me no longer having to manually add all the Exif data whenever I upload to Pentax User.
