In camera Lens correction
Posted 13/03/2011 - 12:52
It does slow it down, but not much. As it's probably only going to used for architectural shots that may not be a problem. I wouldn't use it for sports shots at 6 or 7fps!
I plan to use it when needed when we have our K-5s.
Posted 13/03/2011 - 13:53
is this NOT the Purple Fringing around branches against the sky ??
tried this on my new K7 and I can't see any difference with it ON or OFF !?
K-7 | K10 | DA 18-135 | DA 18-250 | DA 55-300 | DFA 100 |
Posted 13/03/2011 - 13:56
I was referring to ditortion correction, but there is correction for CA as well. It will only work with JPEG capture.
Posted 13/03/2011 - 14:02
it says you can save and use with a raw image, but only if developed in camera ! is that correct ??
Posted 13/03/2011 - 14:05
The lens corrections (both types) with the K7 are applied to the RAW file (if you shoot RAW that is!)
Andy
Andy
Andy
Posted 13/03/2011 - 14:08
for in camera use ONLY though ?? not to LR or ACR ?? right ?
Posted 13/03/2011 - 14:59
Just had a look at the manual and thats how I read it. Data saved in RAW file and for In-camera processing. In that case I'll leave it turned off and use LR instead. Shame but I guess maybe we expect too much sometimes!it says you can save and use with a raw image, but only if developed in camera ! is that correct ??
Vic.
K5, LightRoom 5
Posted 13/03/2011 - 15:18
Doesn't the RAW program suplied also have lens correction?for in camera use ONLY though ?? not to LR or ACR ?? right ?
Any ways for lens correction you need to know which lens is on it, the focal length you use if you use a zoom and the camera you used and all that is already recorded in the EXIF data, and so as far as i know no extra data is being giving to a RAW file if you've the corrections on.
But please prove me wrong
Posted 13/03/2011 - 16:29
I felt it slowed things down a lot on my K5.
This was most noticeable when I was trying to shoot some friends at Go Ape not long ago, and wanted to use machine gun mode for zip-lines etc. I only got every other person, as I was waiting ages for the camera to process the buffer each time.
Not had a chance to try an "on" and "off" shot to see how much difference it actually makes. In future though, for time critical shots, it's going to be switched off...
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Posted 13/03/2011 - 17:21
It does slow things up - ie whereas the shot preview is fairly instantaneous normally, with corrections applied, it is several seconds.
Andy
Andy
Andy
Posted 13/03/2011 - 18:35
Thanks for the heads up on the time delay Guys, I'll keep it turned off I think!
Vic.
Vic.
K5, LightRoom 5
Surrey
Vic.
