I need a lightweight tripod than collapses small...
The limit of the Manfrotto 785b is 1kg so far too little, it wouldn't be very stable and not pleasant to use with the K20D it's simply to flimsy most likely.
£50 is also far to little to spend on a tripod, a good one will last you your life time and a £50 you might throw away after a year in search for something better. Believe me save a little more for a good one.
btw the Velbon CX-460 Mini is £28.70 at amazon.co.uk and they have it in stock
Richard that Velbon Ultra looks also quite nice.
ps. Just looked up the price of the gitzo, it's only $2500,00
Fine piece of equipment though
I can really vouch for the Velbon Ultra Luxi L, my F model is pretty much identical except for the garish gold colour, thank goodness they are now black (they must have listened to their customers! :lol. It can comfortably handle 2 kgs with no real problems, but it's not a Gitzo GT1541T, which can handle an amazing 8kgs! But then, it's affordable!
I've used it so much these days in preference to my large Gitzo 2220 Explorer that I've just sold the Explorer together with all my big heads. Apart from use in very difficult windy conditions or awkward macro shots, I don't miss the Gitzo that much, but I do miss the accuracy of it's positioning especially when used with a Manfrotto geared head.
However, I would like a very slightly larger tripod which has an adjustable centre column and smooth ball head (for macro work). I am currently looking at the various alternatives. I don't want to spend much more than £150 - £200 for the combination, but I may have to go higher in order to get a carbon fibre model for lower weight and rigidity considerations. I will also have to invest in a stone bag link to keep the tripod on the ground when I have the camera and lens stuck out on one side! But I'm not in any great rush.
The gitzo is mighty expensive, I only have a simple ballhead for my velbon monopod from them but it is quality though.
If you want carbon then £150 - £200 seems a bit too little.
Like I said I've my eyes on this one link the nice thing is you can transform the center colum from verical to horizontal in a second so that plus a ballhead would be nice for macro I believe. But then tripod + head you will end up around £300, you do get something for that money though ^^;
btw it seems strange but I believe that tripod gear is cheaper here, so your low pound don't do you much good.
If on your skis, use your ski sticks held crossed with camera resting on top.......
Ah yes the delima of what to get.
The tripod is £176 and the head is £68, so the combo is £244, which is not too bad. The tripod actually has a built in pan and tilt mechanism which you can use without a head which is very handy (page down about halfway in the tripod link).
I shall be visiting my favourite tripod dealer to check them out.
The Manfrotto 055 is a nice tripod, but it's a bit large and heavy, especially with a head, the 190B series is more my size/weight target, but I have my eye on the Giottos MTL 8350B tripod link and the Giottos MH1302-652 head link
If you can find one SH that Polaroid made about 20 years ago from very strong metal, it's the best small tripod I've ever seen. They were cheap and I was sorry I never bought two of them. I've used mine many times with a heavy Rikenenon APO f/4.5 lens and 2x converter. The tripods so strong you could stand on it. The legs stop at 120deg when you open them. I think Minolta sold the same tripod at a much higher price. Came with a good zipped case.
Folds up and looks like a gun , which could be a laugh when you go though customs
Photo of someone elses on Pbase link
shim
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Used as a normal tripod it will just about support the K10D 55-300 + 1,4x converter although that set up is a bit front heavy.
shim
Can anyone recommend a lightweight tripod that collapses down to a nice compact size. I'm not bothered if it's not quite as tall as the others at full height, but i need to be able to carry it in/on my backpack when out on the bike/skis.
Thanks in advance for your recommendations
I would rather make my bag lighter than skimp on the tripod
shim
So both looks very good, the Velbon luxi (exactly what I was looking for!) and both the Velbon CX-460 Mini, while I couldn't find any Cullman Magic.
I need to do some questions about (sorry fir the ignorance!):
1-Is there any reason to buy the Quick release head with Velbon Luxi and above all, what is its use?
2-better a mini tripod like the C460 or a gorillaz? or are simply different thing?
3-Just to understand, some tripods have maximum load 8-9kg. Obviusly this is better for heavy lenses (super super tele) but if my k20d+da55-300 is no more than 1,300 kg, can I benefit from a higher load tripod, or a simply stone bag is a good solution?
4-Which requirements do you look for (like built in spirit level, Quick release plate, etc) when you buy a tripod?
Get my point? Just get used to the weight, and enjoy the fact that your pictures will be so much sharper, due to the use of lower ISO settings, higher apertures and slower shutter speeds. Only because your tripod is rock solid and steady.
Martin.
Cullmann Magic 2 just about steady enough, but very compact for traveling, I've got the Magic 1 which is almost identical, I wouldn't use it other than for traveling.
link
or at Speedgraphic
shim
Velbon luxi L - Culman Magic 2
Maximum Height 161cm - 144
Minimum Height 19cm
Folded Height 39cm - 34.5
Weight 1320g - 1363
Maximum Load 2.5kg - 2.5
Spirit Level Yes
Carry Case Yes
But do I need to buy the head for both of them?
as to the max focal extension that would benefit from mhigher maximum load, do you reckon 2.5kg is not enough?
Do you know anything with a higher one?
Dordrecht,
the Netherlands
K10D, K5
AF-540FGZ
