How to use flash with analog body
crabe919
Posted 18/09/2013 - 14:39 Link
the AF280T is on the shortlist because of the swivel head (wall bounce)!
thanks for the info!
crabe919
Posted 18/09/2013 - 17:26 Link
For the pentax me super, flash syncs automatically @ 125, no slower speed choices here, mx it will be then.
michaelblue
Posted 18/09/2013 - 19:23 Link
On the ME Super.....any speed up to 125th will do so just set the shutter speed manually, remember of course that too much ambient light will cause 'ghosting' though.
Regards,
Michael
crabe919
Posted 18/09/2013 - 19:42 Link
just tried it on the me super, if the flash is on and i put the camera in manual, i can't choose anything, speed is automatically set on 125
Edited by crabe919: 18/09/2013 - 19:42
johnha
Posted 19/09/2013 - 00:18 Link
If the flash unit has an M/TTL or TTL switch, try switching that away from TTL. A lot of independent guns had these switches along with the usual Manual and several Auto settings. Alternatively a cheap non-dedicated gun (or one fired on a PC cord - i.e. not hotshoe mounted) would avoid any problems.
For fill-in flash, you should be aiming for 1:4 (flash:daylight) as 'normal' and possibly 1:2 for 'extreme' situations. For 1:4 you simply set the Auto ISO dial/calculator on the flash two stops higher and read the appropriate aperture for (for 1:2 one stop higher) the film speed you're using. You'll need to make sure the resulting aperture allows a shutter speed no higher than the x-sync though.
John.
crabe919
Posted 19/09/2013 - 09:40 Link
Johnha,
thanks for the guide on how to use the fill flash.
If you say 1:4 for fill flash daylight, do i interpret this as using the camera with the normal exposure needed and ADD a bit of flash?
Any direction of howto tackle evening/night indoors shots? Yesterday i've tried a couple of shots with different setting on a roll. It was too dark for the mx (with iso 400 film) to give a correct exposure, is i put it at 1/60X and set the flash/aperture manually. Is there a better approach for the evening shots?
regards,
Adam
johnha
Posted 19/09/2013 - 11:28 Link
Sorry, I think this is the wrong way round. For 1:4 you need to set the ISO on the flash two stops lower than you're shooting with - to under-expose the flash.
Apologies,
John.
crabe919
Posted 19/09/2013 - 11:32 Link
2 stops lower means if shooting with iso 400 set the flash for iso 1600 (less light required) i guess?
