How long will your battery last.
johnboy-22
Posted 16/07/2012 - 21:52 Link
I have started to take lots of pictures at 7fps and noticed a big improvement in battery life. Also just bought a genuine D-BG4 grip. First one was from fleebay and had plastic pins instead of metal as specified in the picture so sent back. Second one was a genuine one second hand but did not have a holder for the li-ion battery so was sent back. Third one was the brand new Pentax one so at least that will double the capacity.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
Smeggypants
Posted 16/07/2012 - 23:57 Link
ChrisA wrote:
Smeggypants wrote:
Battery consumption isn't proportional to the number of shots obviously so it's not a definitive benchmark.
Clearly not... but what really staggered me was the factor of ten difference compared with my usual experience.
... the amount of AF, live view, and how long the camera is on makes a bigger difference I think
Yes, I've been trying to work out what could be different.
The amount of live view I use is so close to zero as to be irrelevant - I expect it's literally less than two minutes since I've owned the camera.
In normal circumstances I probably do a lot more AFing per shot than I did yesterday. You know the sort of thing... experimental stuff, just generally handling the camera without taking pictures.
So maybe that's what it is - could it be that focusing the lens takes up most of the energy consumed in a cycle of meter-focus-fire?
I only really use live view for f/1.2 shots as the viewfinder isn't accurate enoguh to focus, so not that much in the grand scheme of things.
I rarely use the flash either because of the K-5s great high ISO.
I do cane the AF motor though,
paulgee20
Posted 18/07/2012 - 14:57 Link
Both my K7 bodies give 700+ shots per charge, both on branded and unbranded batteries, appears to make NO difference, (havent had time to really judge the K5 yet). The old K10d was never far behind. The only time this reduces is if you use the camera in excessively cold temperatures.
Live view all the time will obviously pull power all the time and thus reduce shots per charge overall. You can buy extended power third party batteries, (they dont make any diference irrespective of any considerations)! And are by far and away a cheaper and effective option.
K5's (2)both gripped, K10d gripped, Pentax 28-90 f3.5, Sigma 18-250mm, Sigma 150-500mm. Sigma 105mm f/2.8 EX DG Macro, Sigma 10-20 f.4-5.6.EX DC, Hoya 135 f2.8, Take on 28mm f2.8 Pentax AF360 flash, 2 fill in slaves. 30 metre remote release, Rt angle viewfinder, Giotto NOT 3261B Tripod with Manfrotto 808Rd4 ball head, Manfroto 4861RC2 monopoly, shoulder stock, various filters etc, Panasonic SET HBS HD Video cam, Tamrac Explorer 8x backpack and a sore back.....
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index
https://www.flickr.com/photos/pg20
Dave-L
Posted 01/10/2012 - 01:54 Link
Just thought I'd add to this interesting thread (as I can't find a more relevant recent one) that I lost my K-5 battery charger and had to quickly find a replacement locally, so I tried the Jessops 2 terminal universal charger at £19 (£6 online discount with store pickup) and it appears to work well. Charging is slow, about 6 hours - but it has saved my bacon!
K3/K5/10-17fisheye/15mmDA Ltd/18-55WR/55-300DA/100DFAMacroWR/50F1.4M/200F4M/DA*200F2.8/DA*300F4/DA*50-135/DA*60-250/Mitsuki 400F5.6/others.
davidtrout
Posted 01/10/2012 - 10:28 Link
My K5 battery seems to last for ever. I get several hundred RAW shots out of it before I have to recharge, although I've never actually counted just how many.
I never use live view and rarely use the flash but I do frequently check out images on the rear screen.
The K30 battery needs recharging far more often.
felix
Posted 01/10/2012 - 13:35 Link
My K5 battery also seems to last and the only time I needed to do quick changes was when I was on a school trip to Cambodia where I had to take photos of the kids in action and the different architectural wonders.
I have 2 original Li-90s and a 3rd party battery.
