How long will your battery last.
K10D
Posted 04/05/2012 - 08:11 Link
ChrisA wrote:
What's the third contact with the D-Li90 for anyway?
It's the temperature terminal. It is normally referenced to the common or 0v (-) terminal. Should a fault occur or the charger fail and cause an overcharge to the battery, the temp internal (to the battery)sensor detects the rise in battery temperature and terminates the charge.
Some brands actually have the letter T on that terminal so it would read - T + repectively.
Posted 04/05/2012 - 10:14 Link
quote:3496ace15f="ChrisA"]
davidrobinson wrote:
Have you tried another charger, it wouldnt be impossible that its not fully charging the battery?
Now there's a thought. Haven't thought about that one since I returned the original K-5, which did have a different charger.
[/quote]I've found several, but they seem to have just two contacts, not three.
Is that relevant? What's the third contact with the D-Li90 for anyway?
Hi Chris
For my test I will be using the OE Pentax charger, I believe it has more control over charging current and the final result. The reason I think is the "T" terminal is used to feed the charger with an accurate battery terminal voltage and or voltage via a thermistor to give an indiction of internal battery temerature, this gives safer more accurate charging.
If the charger has only two terminals the voltage it uses to monitor charging can be affected by circuit volt drop in the chargers circuit. A battery may for instance be up to 8v but because of volt drop the charger may only see 7.5v. This could cause over charge of the battery. Many 3rd party chargers have a built in temp sensor and or stop charging for a second or two while it monitors battery terminal voltage, this reduces the chance of battery over charge or damage. In addition I believe some non OE chargers may slightly under charge to reduce the chance of battery damage.
See http://www.electronics-lab.com/articles/Li_Ion_reconstruct/ for a typical Li-Ion battery circuit.
I use a Hahnel Unipal charger but only whilst away from home, the batteries seem well charged and so far have never heated up during charging. I have checked terminal voltage after charging and its similar to the Pentax charger result.
MY RESULTS TODAY
I took the Hahnel battery off charge this morning (OE Pentax Charger) and the terminal voltage is 7.85v as is the voltage between + & T.
The voltage after 20 shots with the Bigma set to AF and Stabiliser in No1 was 7.82v across the same terminal positions. If you wait several minutes this voltage may creep back up slightly if the battery is healthy.
Ensure you dont short out the battery and use an accurate Digital meter for the test. Hope this is of help.
Kind regards David
Edited by davidrobinson: 04/05/2012 - 10:40
Posted 04/05/2012 - 10:59 Link
Just to clarify in the case of of the Pentax battery I am fairly certain terminal "T" is a thermistor temperature feedback terminal.
Regards David
ChrisA
Posted 04/05/2012 - 11:01 Link
Yes, based on a number of articles I've found this appears to be so.
Kind regards David
Ok, I fully charged the Pentax brand battery, with the Pentax charger, until the light went out.
The voltage from + to - was 8.34, and from + to T 8.33.
Immediately after 20 shots with the Bigma, also AF and OS=1, this had dropped to 8.27 and 8.26 respectively.
After 5 mins, this had risen to 8.30/8.29.
For comparison, a knock-off battery that's been in the camera for a few days, but still showing full charge, indicates 7.97/7.96.
I'm measuring the voltage using an ordinary digital multimeter which reads to +/- 0.01V, but of course there's no way of knowing how it's calibrated - I only have the one
It's not really evidence for an undercharged battery, though.
Posted 04/05/2012 - 14:35 Link
Kind regards David
Hi Chris
From the voltages you have given the battery sounds to be in good order but open circuit voltage doesnt always reflect the Mha capacity of the battery. Even so I wouldnt think the battery/charger are at fault. If possible I can you swap identical fully charged batteries with someone near you and compare the number of images they will take from fully charged to flat.
Sorry but I cant think of anything else at the moment.
Regards David
ChrisA
Posted 04/05/2012 - 14:49 Link
Regards David
Well this is the thing. I've had effectively the same results with three different batteries.
I really don't want to do the test properly - click click click, till the battery is exhausted - and then for the other battery.
A bit of a waste of 300 shots really
johnboy-22
Posted 06/05/2012 - 20:05 Link
ChrisA
You are getting exactly the same results as mine. Will try and bring a meter home to check the voltage.
Pentax K5, Kx, DA15 ltd,18-135, 18-55, 50-200, M100 f4 macro, M135 f3.5 A28 F2.5
johnboy-22
Posted 07/05/2012 - 19:12 Link
Charged the pentax battery for about 16 hours and was taken of charge this morning. Checked the voltage tonight and was 8.35 volts
bwlchmawr
Posted 07/05/2012 - 19:28 Link
Two weeks abroad with my K10 on one battery charge, camera still showing full when we returned.
Energizer AAs last for weeks in my K100.
One day with Optio S1 and the red warning was flashing...
Best wishes,
Robert Adams
Ernst Hass
ChrisA
Posted 07/05/2012 - 19:50 Link
Talking of the K10D, that was my main camera before the K-5. My usage style hasn't changed at all, AFAICT, and I used to get over 400 shots per charge, easily. It would go months and months without charging if I was in a quiet period.
At two Farnborough airshows, about 1200 shots each, I'd just got on to the third battery.
Gonna need a lot more than that with the K-5 this year.
vrapan
Posted 07/05/2012 - 22:09 Link
400-500 shots per battery. Over 1k with the D7k that is quite a difference but the D7k does not have an IBIS and I never used it with a VR lens (never owned one) . Having said that the 50% reduction is quite a lot and I was hoping I'd get more like 600-700 shots per charge.
One of the very very few black spots on an otherwise fantastic camera which I have solved by purchasing a couple third party batteries.
dougf8
Posted 10/05/2012 - 06:18 Link
Hahnel battery, 8.09V after 165 shots yesterday, charges up to 8.26V sitting overnight.
Still showed full before charge.
Lurking is shirking.!
ChrisA
Posted 16/07/2012 - 14:24 Link
Thought I'd update this thread with an interesting discovery from yesterday at Farnborough.
I got 1400 shots out of the first battery
I'd been expecting to have to change battery every 150 shots or so, so I took 6 with me in total, all fully charged, and was expecting to have to ration myself severely.
The first change came shortly after starting on the third 16 GB card; the first two had a little over 700 shots on them each. And even then it wasn't completely dead - it was showing one bar but recovering to two after a switch off. I just changed since I didn't want to be caught out.
So, it very much begs the question - what's happening the rest of the time?
It's incredibly rare for me to take more than a few tens of images on any particular day - airshows are pretty much the only time I'd take 1500 shots in a day.
But I was truly amazed at the difference.
Smeggypants
Posted 16/07/2012 - 20:00 Link
Doesn't shock me at all. I've had upto 2,000 shots with one battery ( both Pentax badged AND 3rd party badged ) - Did a > 4,000 shot shoot once with 2 K-5s. Only had to hcange one battery on one of the K-5s at the end of the day. I always take 2 spares with me though just in case
Battery consumption isn't proportional to the number of shots obviously so it's not a definitive benchmark. the mount of AF, live view, and how long the camera is on makes a bigger difference I think
ChrisA
Posted 16/07/2012 - 20:52 Link
Clearly not... but what really staggered me was the factor of ten difference compared with my usual experience.
... the amount of AF, live view, and how long the camera is on makes a bigger difference I think
Yes, I've been trying to work out what could be different.
The amount of live view I use is so close to zero as to be irrelevant - I expect it's literally less than two minutes since I've owned the camera.
In normal circumstances I probably do a lot more AFing per shot than I did yesterday. You know the sort of thing... experimental stuff, just generally handling the camera without taking pictures.
So maybe that's what it is - could it be that focusing the lens takes up most of the energy consumed in a cycle of meter-focus-fire?
