How Likely am i to get dust on my sensor?
You haven't said which lens you have, if it's a DA* weather sealed lens, I'd say you'll have no problem.
The coast + city centres = sand + debris + very fine dust. If it's not a weather/dust sealed lens, you could get sensor contamination.
Some lenses cause a mild vacuum action as their parts "zoom" in and out, often sucking dust directly into your camera. So in that case, probably 100%.
But how long it will take until something significant enough to notice gets stuck there??? Probably quite a while. Taking the lens off is probably the biggest culprit.
The coating on the K10D sensor really seems to keep a lot of dust from sticking in the first place.
A sealed lens (DA* 50-135 or DA* 16-50) should almost totally eliminate dust getting into your camera.
Bring a small rocket blower, and you should be good for 95+% of dust. I have et to need more than to give a quick shot from the rocket blower to get any irritating dust off my sensor.
I still wonder though, about seals inside places such as when you remove the battery or SD card? I'm hoping those are sealed so that dust that always builds up there will say out. The outer doors are sealed but those do open and allow dust in... I just don't know how far.
But over what time frame? Who knows. Could be a while. Really depends on the environment (sandy beach, dusty race track, or clean room?).
I was on two week vacation on boat and land with a sigma 18-200 lens (kept the same lens on). Never had a problem with noticeable dust getting in. (and that was back with my old istD which seemed to send out invitations to dust sometimes.)
I would not obsess over it. Even a little dust is easy to get rid of with a blast of air, or later through Photoshop... although perhaps a little irritating on a thousand+ photos from a trip.
Do not test by photographing a white piece of paper (over-exposed) at F32. It will show up every minute imperfection and you will go nuts trying to get rid of all of it. Test at F22 or F16 instead.
Better still, don't test at all and only clean your sensor if a dark speck or blob shows up on one of your normal photos.
I have read this often and observed it in experience, but in my simplicity I don't understand why small apertures make dust on the sensor more visible. Please can someone enlighten me?
Michael
A tip for those at risk of becoming obsessed with sensor cleanliness:
People who get obsessive about dirt on their lenses have been known to rub the coating off.
"dont get obsessed" part as once you enter that route its a rocky route!!
The size of the lens aperture affects the angles that light enters and therefore the nature of any shadows formed. There are websites that explain the details better than I can, that you should find via Google.
A small aperture results in the dust speck forming a small dark shadow. A large aperture results in a larger but more difuse shadow. Typical large apertures will make all but the largest pieces of rubbish on the sensor invisible on your images.
Kent
