How do I know whan a Lens is a macro lens
Posted 21/11/2010 - 10:18 - Helpful Comment
Hi there
If the lens has some/all of these markings is one way: -
Has it got any of the following stamped on it
N/AI or OM or MD, 1.1, (at least 1.1, better than 1.1 improves, I.E. 2.1/5.1
Macrolenses are expected have at least a 1:1 ratio between the image produced and the subject's size. More expensive macro lens can have greater magnifications, such as 5:1, which means the image in the picture will be five times larger than it is in real life.
Then this points you in the right direction
A cheaper option if your budget is really tight at the moment could be: -
Close up lenses (or supplementary lenses) are perhaps the cheapest alternative of getting into Macro Photography on a budget. These small lenses screw into the filter thread of your camera’s existing lens and allow the lens to focus closer than it’s normal minimum focal length. In doing so they allow you to fill more of the frame with your subject.
These lenses often come sold in a set of 3 and are labeled as +1, +2 and +3 etc (with +3 being the largest magnification).
However you do lose focus at infinity and some quality as you are adding an extra element.
Plenty of these can be found fairly cheaply on E Bay or similar: -
http://cgi.ebay.co.uk/PENTAX-SAMSUNG-fit-100mm-Macro-Prime-LENS-DSLR-MINT-/16050...
Paul
Paul
K5's (2)both gripped, K10d gripped, Pentax 28-90 f3.5, Sigma 18-250mm, Sigma 150-500mm. Sigma 105mm f/2.8 EX DG Macro, Sigma 10-20 f.4-5.6.EX DC, Hoya 135 f2.8, Take on 28mm f2.8 Pentax AF360 flash, 2 fill in slaves. 30 metre remote release, Rt angle viewfinder, Giotto NOT 3261B Tripod with Manfrotto 808Rd4 ball head, Manfroto 4861RC2 monopoly, shoulder stock, various filters etc, Panasonic SET HBS HD Video cam, Tamrac Explorer 8x backpack and a sore back.....
Photography is an index for measuring futility and pride.......
Paul
:wink
http://s743.photobucket.com/home/pg20_photos/index
https://www.flickr.com/photos/pg20
Paul
:wink
Posted 21/11/2010 - 10:32
Many lenses with 'Macro' in the name are not true macro lenses which have 1:1 magnification ratio meaning the subject will appear life size in the image.
True macro lenses tend to be very expensive, both the current Pentax offerings are just short of £400.
For your budget you might consider a second hand 50mm prime such as the Pentax A version and a set of extension tubes.
Posted 21/11/2010 - 10:36
Not sure about the 1:1 part many earlier macro lenses only could do 1:2 and still some are available, like the Carl Zeiss macro's.
I think the biggest defining difference is that Macro lenses are specially made to preform the best at close focus and they also have a very flat field of focus because of that, therefore only Prime lenses can be true macro lenses.
Zoom lenses with macro function only means you can focus close with them but they don't come close to what a real prime does/can in therms of quality, the zoom lenses aren't made for that.
Focal length change the prespective of the macro.
50mm give a wider "immersive" view than a 100mm which more isolate the subject.
Also the 1:1 distance with 50mm is closer then with 100mm. With 100mm it's around 30cm, 50mm around 20cm so with bugs a 100mm would be better.
Posted 21/11/2010 - 10:38
Pentax Users might expect to be looking for a lens marked as having a PK mount of some type, rather than Nikon, Olympus or Minolta!Has it got any of the following stamped on it
The older pentax macro lenses (50mm or 100mm) are usually f4 lenses with a maximum magnification of 1:2 (half life size) and a special extension ring increases that to 1:1
Later macro lense (A, F, FA, D-FA)are usually f2.8 and focus right down to 1:1
Posted 21/11/2010 - 10:39
A macro lens is (theoretically) a lens that (at least) allows you to get a real size image of an object on the sensor.
So a subject of 1 cm diameter will be 1 cm on the sensor (or bigger)
Others state that macro already starts earlier (e.g. 50%).
If a zoom says macro, it's often not able to achieve 1:1 (not 'real' macro)
You can consider the use of an adapter (Raynox is a name that is mentioned quite often) instead of a dedicated lens; not sure about prices.
Posted 21/11/2010 - 10:43
Sorry John, forgot to clarify that.
Paul
Paul
Paul
:wink
Paul
:wink
Posted 21/11/2010 - 10:58
Available 2nd hand are special 2X Macro Converters. These act as a normal two times converter and also have an adjustable macro setting. Used with a 28mm lens it becomes 56mm macro lens. A 50 mm lens becomes a 100mm macro etc etc.
I have the Teleplus version of this macro converter and am pleased with the image quality when using Pentax primes.
Friendly Regards
Graham
Graham
Posted 21/11/2010 - 11:45
I have heard of the Raynox and they seem to be from 50-100 depending on model..
Have just seen this on ebay
M42_Vivitar
Bit bigger than Id like, but has good reviews..
I know I would need to get a M42 adapter, but it would be a handy thing to have for older lenses..
Or there is this?
convertor
Maybe I should mention that I only have the 18-55mm kit lens!
M42_Vivitar
Or there is this?
convertor
Pentax K20D is mine
Pentax-M 100mm f4 Macro K
Oh, what have I started!
Posted 21/11/2010 - 12:07
The Vivitar you linked to is a Zoom lens having some macro'ish capability. All true Macro lenses are primes having a fixed focal length and are (IMHO) the only real option for decent macro work.
Macro zooms tend to simply adjust the internal elements to allow for slightly closer focussing at shorter distances than they otherwise can and you lose focus at infinity. The loss of infinity focus is not a real issue but a true macro lens can focus from very close to infinity without a problem.
All other options to achieve macro images can produce good results with patience but a dedicated macro lens is best. One of the Dixons group was selling the SMC Pentax D-FA 100mm Macro lens recently for under £300, a real bargain.
The cheapest 'entry level' option to macro photography is a standard 50mm prime lens and a set of extension tubes. I would try that first because there is no point investing several hundred pounds in a macro lens if you eventually discover you haven't got the patience for it, and you need that by the bucket load.
Other options include reverse mounting a wide angle lens, say 28mm, on your camera for which you will need a reversing adapter (male K mount to male filter thread to match the chosen lens).
My least favourite option is to stack two lenses, one reverse mounted to the other, for which you will need stacking rings (dual male threaded). EG: A 50mm lens stacked onto a 200mm lens which is mounted to the camera will result in magnification of approx 4X. It borders on micro-photography though, rather than macro-photography.
Posted 21/11/2010 - 12:24
You say that you want close up's of plants etc. That is not macro photography. Quality close up shots can be obtained with prime lens. I use 200mm and 300mm. I do have the Pentax 100mm 2.8 but it is limited with depth of focus for 'close up' work.
You need to be very clear in what you want to photograph. If you want ultra detail of small subjects, then macro is your aim. If you want real detail of, say lillies, the close up is your aim.
Suggest you try to find someone with a true macro lens and try before committing yourself.
Posted 21/11/2010 - 12:58
The 18-55 can focus pretty close, just as close as most zoom "macros"Maybe I should mention that I only have the 18-55mm kit lens!
Set the lens on 55mm and the focus on the closets settings and move your camera/body till you get the focus right.
It should be able to do 1:2,9 that way, good enough for plants and for big insects maybe???
Posted 21/11/2010 - 13:56
OK, I obviously need to narrow it down a bit, having gone the the complete quagmire that was choosing a camera, I am slowly sinking under the weight of choosing lenses. Half the problem is that as a noob, I just have no idea what the various numbers actually mean in real world pictures.
I know 50-200 or 55-300 is a zoom
I know a prime is fixed length
But I have no idea what differnce there is between a 50mm prime and a 90mm prime when it comes to the actual photo.
Im aware that I have alot to learn!
Now I have a K20D, I want to play with water drops, cliched yes, done before - lots, but it is something I have always enjoyed looking at and I want to have a go...
Im guessing that I need a macro as it is close up photo? Or a prime with and extension.
I also want to get a 2nd hand prime as new lenses are out of my price range, this is because I want to be able to get some nice DoF shots.
I do need a prime for that - right?
If I can get a prime that will allow me to do both, then that would be great. Im looking to build up (slowly) a nice collection of 2nd hand glass. That is part of the reason why I chose Pentax over Canikon, for the availability of good 2nd hand glass. But looking on ebay, the choice is massive and I don't know what is a good lens. I know most lenses will fit my 20D, but Im getting confused now.
Pentax K20D is mine
Posted 21/11/2010 - 14:05
50mm f/1.7 is good lens for stacking and because it's a f/1.7 that means the aperture is relatively larger so the DOF is small.
Also the lens is very cheap secondhand
Here is a nice tool to see what the focal length does so you can see the difference between 50mm and 90mm http://www.tamron.eu/en/lenses/focal-length-comparison.html
Here is a read about lenses, it can be a bit technical but i hope it helps
http://www.cambridgeincolour.com/tutorials/camera-lenses.htm
Posted 21/11/2010 - 15:08
Most of us have been there. It is a large learning curve you face. This Forum will offer you a lot of advice. Until you put it to the test to discover if it is for you then you will not gain the most valuable lesson..that is..experience.
If you have a camera club near you then this will be your fastest route to experience. Members are only too willing to help and advise and offer practical support. You will find that the members will encompass most of the photographic disciplines. Camera clubs are not for everyone but for beginners they are invaluable for avoiding the costly mistakes that we all make at some time.
Being in London you have many camera shops to visit. Some will advise and even let you try lens. Give it a go.
regards thoramay
regards thoramay
London
I want a macro lens, as I want real close ups of plants and insects, water droplets etc, but Im realising that unless it has 'macro' in the name, I have no idea if it is a macro lens or not..
Wikipedia has helped with the Pentax naming scheme, but Im still a bit stumped..
Is there anything in the focal length or other numbers that will help me to identify whether a lens is a macro lens?
Anyone have any recomendations for good old macro lenses, Im guessing old as I cant really afford to go much above £80. Buying the camera cleaned me out pretty much, though Im a very happy man now
