How do I keep Iso on 200?
Posted 13/11/2011 - 10:32
You need to go into the ISO section but make sure you save the setting you choose. Don't set auto ISO, have that switched off.
Posted 13/11/2011 - 10:38
Hi it is on auto, how do I turn it off, what button do I need to press please? Sorry, its very confusing.
Always be kind to people
link
https://www.facebook.com/pages/Photographs-by-an-angel/262352847143059
link
link
link
Posted 13/11/2011 - 11:04
Menu>Sensitivity>set 200>Click OK.
Also:
Menu>Memory>Ensure Sensitivity is ticked. If not click OK to set it and then return to the menu. Now the camera will memorise whatever ISO was last set.
Also:
Posted 13/11/2011 - 16:41
the iso corction (that's how its spelt) is set to 800, should I put that down to 400 please?
I also take the battry out when I am not using it, is that a good idea?
link
link
link
link
Posted 13/11/2011 - 16:50
If you set a given ISO and then make sure the memory is set to remember last settings then next time you switch on the setting will be the same.
However, if you take the battery out after a while the memory will be lost, so keep the battery in and charged so the camera is always ready for use. Only take the battery out if the camera is to be unused for months or longer.
Posted 13/11/2011 - 17:07
Hi thanks for that, I was told if I left the battery in it could leak and ruin the camera.
link
link
link
link
Posted 13/11/2011 - 17:25
It just goes to show how well meaning advice can cause other problems! The advice was right, but needed qualifying as to how long the camera would be left unused.
All my cameras have batteries in, fully charged and ready to go, unless they are to be unused for many months, in other words are being stored rather than used.
Posted 13/11/2011 - 18:06
Hi, its a case of experimenting really.
link
link
link
link
Salisbury
link
link
