High Speed Flash Sync
karthikv82
Posted 22/09/2010 - 08:42 Link
Hello All,
I have two YN560's and a Metz36 but both do not do high speed flash sync with my KM. Looking for a cheap flash that would do my high speed sync and TTl.
I found this on Amazon - link
Not sure if I want to spend that much so anything cheaper ?
Thanks,
Karthik
Anvh
Posted 22/09/2010 - 19:13 Link
Can't get really cheaper than that.
The flashes that can do HSS are
Pentax - AF360FGZ, AF540FGZ
Metz - 48 AF-1, 50 AF-1, 54 MZ-4i, 58 AF-1
Sigma - EF-530 DG Super
Your best bet would be the Metz 48.
Why do you need HSS for btw?
Stefan
K10D, K5
AF-540FGZ
karthikv82
Posted 23/09/2010 - 08:05 Link
Thanks Stefan ... honestly .. i now dont remember why I wanted one... probably spur of the moment thing when I saw a demo if high speed flash .. and thought thats kool I need one of those. Now being in my senses .. Its something I think is good to have but not a "need"
Regards,
Karthik
gartmore
Posted 23/09/2010 - 09:02 Link
You mentioned ttl, your camera doesn't support ttl. It only supports p-ttl.
Posted 23/09/2010 - 11:13 Link
BTW, don't think that HSS is simple
It involves creating multiple bursts of light as the shutter progresses. 1/180s is the fastest speed where the sensor is completely exposed in one go.
Faster shutter speeds are achieved by creating a moving 'slot' between the leading and trailing curtains of the shutter. It's this moving slot that creates the challenge for HSS flash - it has to fire so the image is exposed evenly all the way down.
Consequently, only the big and expensive flashguns can support HSS - it's much more sophisticated from the flashgun's point of view
Often people say they want HSS.... but don't really know why It is very helpful in bright conditions where you want fill in flash. However, a reflector is often an easier and cheaper method in those circumstances
HTT!
Edited by MattMatic: 23/09/2010 - 11:14
Mike-P
Posted 23/09/2010 - 11:58 Link
I use it for macro to pick out the detail. WIth a diffuser on it seems to be a lot more subtle than normal flash.
May be totally the wrong way to use it but it seems to work ok.
Clarky
Posted 23/09/2010 - 14:48 Link
I totally agree I use it sometimes myself.
Camera:|K-7|
karthikv82
Posted 23/09/2010 - 18:40 Link
The initial idea was to use it as a fill in flash and some creative macro photography ... but i figured its not an absolute must have .. as I have been doing a lot of flash photography without it.
Ken .. I did mean P-TTL
Edited by karthikv82: 23/09/2010 - 18:40
