Quick Question. Rear Sync on Pentax Kx
ElRazur
Posted 25/09/2010 - 19:58 Link
I was reading Scott Kelby's book and on the section for Portraits, he advised using a "rear sync" function in the flash setting to capture more background. (His example was for canon and nikon)
I am not sure this function is available on a Pentax Kx or is it called something else? I am not sure this function is available on the Af360 flash gun either.
Can anyone shed further lights? Thanks.
Gwyn
Posted 25/09/2010 - 20:06 - Helpful Comment Link
This is also known as trailing curtain sync. The AF 360 certainly has it - look at your handbook.
No idea if the Kx has it - it will be in the flash menu if it does. Again read your handbook.
Edited by Gwyn: 25/09/2010 - 20:06
ElRazur
Posted 25/09/2010 - 20:18 Link
Thanks. I saw it, but the explanation was a bit different from what Kelly was saying.
Once again, thanks.
Anvh
Posted 25/09/2010 - 20:20 - Helpful Comment Link
Like Gwyn said, Pentax calls it Trailing curtain sync and the pop-up flash of the K-X can do that.
Also the Af360, it's the icon with the flash on the differnt side of the arrow (sorry that I can't be clearer)
Stefan
K10D, K5
AF-540FGZ
ElRazur
Posted 25/09/2010 - 20:22 Link
Thanks. Just wish they would just call it same name. Too many different names and more or less similar functions lol.
Anvh
Posted 25/09/2010 - 20:23 - Helpful Comment Link
Yes, but rear sync or trailing curtain sync are the same thing.
It's that the flash only fires just before the last/rear/trailing curtain closes.
Normally you wouldn't say that would have an effect to get the background brighter with flash but with these modes the camera meters as normal like without a flash so you get a longer exposure so more ambient/background light on your photo.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 25/09/2010 - 20:23
Gwyn
Posted 25/09/2010 - 20:23 Link
Yes Scott Kelby's description is a bit different but that's what it is.
