Help with lens mount
Posted 12/09/2010 - 14:55
No idea. Is it a breech lock like Canon FD?.... does the
rear cap not have anything stamped in it?
Have a close look at any good shots of Tamron adaptall mounts
on ebay see what's similar.
Posted 12/09/2010 - 17:47
Posted 12/09/2010 - 18:44
With that notch being more in the middle of the bayonet, to me it looks more like the Konica in your list, Algi
Barrie - Too Old To Die Young
Posted 12/09/2010 - 23:58
Just had a quick look at one of my Minolta MCs and can confirm it's not one of those. The notch is in the wrong place and the flanges are in a different position relative to the actuating lever.
Al
Al
Posted 13/09/2010 - 11:23
cardiff_gareth wrote:
It says MA on the rear of the lens. A quick google brought this up:
Does that look like your mount ?
I just tried putting MA EE.22 into Google and I got:It says MA on the rear of the lens. A quick google brought this up:
http://www.myspace.com/maeekroft
Not exactly Camera Mounts
Posted 13/09/2010 - 11:53
binhnguyen wrote:
Thanks for your response.
This is not Canon FD, doesn't look like it either. It doesn't has anything stamped on. I also know the Tamron adaptall but this is not that, too
Thanks anyway.
The YS was actually Sigma's interchangeable mount system. Try saving a search on ebay for YS Pentax mount also YS M42 one might come up.Thanks for your response.
Thanks anyway.
One sold here
Posted 13/09/2010 - 13:01
Some good info there on the buktus site. Looks like it will
need the Pentax/Practica mount.
The ebay link is the same supplier I linked to. I didn't think of looking
if they had others for sale.
That looks to be the correct mount, but it might need a bit of work
doing on it to hold the pin in if the lens hasn't got a manual
switch. Possibly glue it in or put a piece of cable insulation
on it from behind.
Edit: Gareth did you ever get that M42 adapter with the
flange and if so does it work? I could do with one for
a Yashica 50mm f/1.7
on it from behind.
Posted 13/09/2010 - 15:12
Thanks, I might order one.
Generally Yashica's are sharp especially wide open and very well made. Yashica owned Tominon/Tomioka. Their f/1.2's go for £300+
The f/1.7 can't be put back together if you modify the pin with a piece of insulation, so it's either glue it or get an adapter with a flange.
First I've got to get it back together. It's a bit like a Rubik's Cube
Posted 26/01/2020 - 03:00
Solved.
Yes, it’s been 9 years since your post- but for others who have stumbled upon this post like I did, trying to sort out what this mount is- the guy who said it looked like a Konica was correct. I have 3 and I tried it on my Konica TC. It went right on. I assume all 3 have the same mount. They’re recent buys, so idk. Thanks to the op and good luck to anyone else dropping by!
Posted 26/01/2020 - 11:18
Imsland wrote:
Solved.
I'm pleased to hear it
Solved.
Recently I bought a Sigma Micromacro YS 100mm f/2.8 lens thinking that is is in Pentax PK mount. Unfortunately in turns out that the mount is not PK though it looks a bit similar. I post some photos of the lens and the mount here hoping someone would be able to let me know what mount is it. Thank you.
[IMG]http://i42.photobucket.com/albums/e343/elektriman/Sigma100f28Unkown/IMGP6795.jpg[/IMG]
