Kr autofocus problem
Posted 03/03/2017 - 16:29
1. Recharge the battery
2. Take the lens off and clean the contacts on both camera and lens with a lint-free cloth
3. Pray
3. Pray
Posted 04/03/2017 - 00:32
3. Pray
Tried all that, even prayed no luck still continuously trying to focus with no luck in any mode
3. Pray
Digital Equipment: Pentax Kr, Pentax SMC DAL 18 -55mm & 50-200mm Zoom Lens, Pentax k100d, SMC DA 18-55mm, Tamron 70-300mm LD Di 1:4-5.6 TELE-MACRO lens, Jessops 280D flashgun, Hama Star 63 tripod and Jessops monopod.
https://www.flickr.com/photos/scotia_photographic/
Posted 04/03/2017 - 00:33
Mike-P wrote:
4. Make sure the camera isn't set to manual focus.
Definitely not on manual
Posted 04/03/2017 - 00:53
Had you set the camera to only focus with the back AF button? I've thought the same as you before now and that was the reason.
Posted 04/03/2017 - 00:55
Ok , what happens when you press the AF button on the rear of the camera...ie not by shutter button half press ?
Posted 04/03/2017 - 00:56
We must stop doing this !
Posted 04/03/2017 - 10:41
Hi John, Had you set the camera to only focus with the back AF button? I've thought the same as you before now and that was the reason.
Sorry if I sound dense or stupid but how do I check this
Posted 04/03/2017 - 11:00
It will be in the settings. But what happens if you press the AF button on the back of the camera ?
Posted 04/03/2017 - 11:20
pschlute wrote:
You won both cameras this time so I'll give you your one back from last time.
We must stop doing this !Had you set the camera to only focus with the back AF button? I've thought the same as you before now and that was the reason.
Posted 04/03/2017 - 11:21
pschlute wrote:
Yes, if that focuses the camera the AF is working fine, it is just a setting. Worry about which setting later!
It will be in the settings. But what happens if you press the AF button on the back of the camera ?JAK wrote:
Posted 04/03/2017 - 11:22
pschlute wrote:
When pressing the AF it does the exact same the lens motor just seems to make the focus go in and out trying to focus but won't if you know what I mean.
Posted 04/03/2017 - 11:24
When pressing the AF it does the exact same the lens motor just seems to make the focus go in and out trying to focus but won't if you know what I mean.[/quote]Sorry forgot to say it does it with all lenses
It will be in the settings. But what happens if you press the AF button on the back of the camera ?scotiaphotographic wrote:
[quote:3496ace15f="JAK"]Had you set the camera to only focus with the back AF button? I've thought the same as you before now and that was the reason.
Hi John, [quote:3496ace15f="JAK"]Had you set the camera to only focus with the back AF button? I've thought the same as you before now and that was the reason.
Posted 04/03/2017 - 11:26
When pressing the AF it does the exact same the lens motor just seems to make the focus go in and out trying to focus but won't if you know what I mean.[/quote]Ah, I think we've all misunderstood and thought the AF didn't do anything. So it does, but doesn't select a focus point? Is that right?
