HELP Pentax Battery Charger Lost!!!!
Posted 26/05/2013 - 21:14
I got one of these from Amazon. Works a treat on 240v. Indicator to show how much charge in battery as it charges. 12v carcharger and travel different countries..
http://www.amazon.co.uk/Ex-Pro%C2%AE-Pentax-D-LI90-DL-I90-D-Li90/dp/B0062LKD62/ref=sr_1_6?ie=UTF8&qid=1369598888&sr=8-6&keywords=pentax+k5+charger
I think there is an ExPro one cheaper without indicator.
Pat
Pat
Posted 26/05/2013 - 21:55
That looks the same as the £8.95 one on Amazon. Whole 2p cheaper!!!
I also got 2 K5 batteries off Amazon for under £5
They perform as well as the Original with over 1000 pictures to a charge.
Don't know if they were good value or not until I use them for 10 years, but so far at 1 year old they still seem as good.
Pat
Pat
Posted 26/05/2013 - 22:47
Pat
Perhaps you should check the price on the link you provided - Price on your link £13.97 - price on ebay £8.97 - a difference of £5 - as I stated or should that be a "whole £5 cheaper!!"?That looks the same as the £8.95 one on Amazon. Whole 2p cheaper!!!
Pat
Carl
Posted 27/05/2013 - 01:17
Actually, the £13.97 on Amazon in NOT the same as the £8.97 ebay charger. The £8.95 Amazon on is the same as ebay.
Two different sets from the same manufacturer.
Posted 27/05/2013 - 03:04
What concerns me with these chargers is the lack of fused protection.
I bought this charger
Ad then added this plug
If like me you always leave your chargers in I would prefer the benefit of a fused plug / adaptor.
Concert photography
Concert photography
Posted 27/05/2013 - 07:39
I doubt the 3A plug fuse will blow before the charger's internal PCB-mounted one...
Posted 27/05/2013 - 08:31
cabstar wrote:
If like me you always leave your chargers in . . .
That's both a waste of energy which is costing you money, and a fire hazard which could cost you very much more, even your life and the lives of others.If like me you always leave your chargers in . . .
Always unplug or switch off electrical appliances when not in use.
A simple solution is to connect all of your chargers to a switched extension lead.
Posted 27/05/2013 - 08:42
Thanks Gamka. I did say that Amazon had two different ones.
There must be other makes out there, I can only say about what I actually have used.
Pat
Pat
Posted 27/05/2013 - 10:14
Do you switch off everything when not in use? I doubt it. Cooker, washing machine, microwave, TV, radio, burglar alarm, ...Always unplug or switch off electrical appliances when not in use.
So, all connected to an extension lead - what do you do when you only need one of twelve? Unplug every other one?
Posted 27/05/2013 - 10:16
The adaptors are a bit cheaper from CPC-Farnell (good company to deal with!):What concerns me with these chargers is the lack of fused protection.
http://cpc.farnell.com/pro-elec/rw6013l/adaptor-3a-plug-to-fig-8-c7/dp/PL11185?N... - Free P&P at the moment
Posted 27/05/2013 - 10:26
There may not even BE an internal fuse - sometimes the transformer windings or a thin PCB track acts as the "fuse"!I doubt the 3A plug fuse will blow before the charger's internal PCB-mounted one...
Also, the following supplier offers 4x types of plug adaptors: UK (without fuse!), and the Continental, USA & Australian versions (NONE of which have fuses in any versions from anybody anyway)
http://www.ebay.co.uk/itm/Battery-Charger-Pentax-D-LI90-DLI90-K-7-K7-K-5-K5-645-...
If you ask, for a small extra charge, they will supply extra types of plugs - so I bought both K-5 and K-R battery chargers and two sets of the UK, US and Continental plugs - total of less than £23 in total inc P&P.
(but now I use the 13A adaptors from CPC!)
It seems you also get a car-charger adaptor - but I did not get that.
Posted 27/05/2013 - 13:13
Thanks guys
Posted 27/05/2013 - 13:54
Thats a good price, ordered a few, I like these leadless figure 8 adaptors.
Concert photography
Concert photography
I have lost the charger for my K-5 battery while on holiday and want to know where I can find another replacement.
I dont want to buy the same one as its a bit expensive.
Any ideas or links to cheaper alternatives.
QC
