help me please
puma
Posted 20/11/2012 - 20:16 Link
I have been asked to write an article on how to get that shot? For beginners in photography for a local magazine, and to be honest I haven’t got a clue on where to start any one got any good ideas?? I can take photos but I can’t write bugger all
PPG link
CMW
Posted 20/11/2012 - 20:26 - Helpful Comment Link
Hey, you're being unnecessarily modest! Just write it autobiographically -- how you do things. I'm pretty sure that some tales of how you got particular shots in a particular way will be worth any amount of 'in theory' writing.
Regards, Christopher
ChristopherWheelerPhotography
davem
Posted 20/11/2012 - 20:38 - Helpful Comment Link
I would suggest that you think of a good photo you have taken and then break down the process you went through to get it. This would give you a number of steps which you can describe in your own friendly style we all know and love
Dave
bettyswolloks
Posted 20/11/2012 - 21:43 - Helpful Comment Link
Dave
I think thats the way forward mate.
Just try and breakdown the thought process you went/go through to get THE shot, then have a go at putting into words. You could recount a story of how you got a good shot, from the 1st time the idea came to you through to any prep work and finally getting it in the bag.
Good luck though, writing this has made me realize the job you have on
Stuey
Posted 20/11/2012 - 21:45 - Helpful Comment Link
Hi Shaun
The trend in magazines either seems to focus on what someone did at a sepcific time which applied to that 'specific' situation or gives the the best photo is the one you like approach such as 'if you like rainbows go out after rain' or 'for seals go to....' etc and is fairly non committal.
At a guess I reckon you will do a better job of it once you get through the writers block alcohol is known to help free up the blockages between brain and writing hand
That's why I probably why I got a 2.1 in my degree and not a first
Whilst my photo's are not the greatest my writing is probably worse but here would be my tips
First write done your brief - ie what kind of shots you are referring to, I guess landscapes or studio workand make this an intro to which your main body will explain more in detail.
Secondly write down your preferred approach, times of day lighting, what weather to look at or in studio lighting, backgrounds to use, and refer back to the points in the intro but in more detail effectively reiterating the points made
Thirdly, express a few possible variations then advise them to tailor what they do to the specific situation with a few tips then
Forth, summarise what you have already written keeping your 'headline tip or tips' for this part and conclude then open a beer and let someone else (wife/daughter etc)proof read it for you, reword it and close the paragraphs etc and then you should be pretty much done
All the above is, is my vague recollection of how to write a short essay there may be better people too take advice from other than myself though
My Flickr site link
davidstorm
Posted 20/11/2012 - 22:29 - Helpful Comment Link
If it's for beginners, I would keep it simple Shaun. I would also break it down into bite-sized chunks like for example:
- Basics of correct camera usage to get a correctly exposed and focussed image (simple exposure, metering and focussing tips)
- Camera craft, e.g. holding it steady, composition tips etc
- Recommended locations (or types of locations)
- Using light to best effect
- General advice, e.g. getting out and about, best times of day, techniques for different seasons
You could include all of the above in an autobiographical style as suggested above, i.e. choose a few of your favourite images and write about how you shot them, including some factual tips on subjects such as those I've suggested above. For example, if you were shooting inside, did you use flash, if so what settings? If you didn't use flash how did you get enough light and the right quality of light and how did you keep the camera steady if there was poor light?
You haven't mentioned how long the article should be, so this may be a factor in how little or how much you include, also do you need to include processing tips or is this just about getting the shots?
puma
Posted 20/11/2012 - 22:50 Link
Well that’s helped me really has thank you all for that,
I will post what I write and let you see it before I pass it over to them so you can all have a laugh
thanks for the help
PPG link
cabstar
Posted 20/11/2012 - 23:02 - Helpful Comment Link
If the magazine has a good sub editor they should make it more professional and fit in with their style.
When I first started writing I was given a list of the magazines writing style, a dos and donts.
Maybe they can help you with this.
Concert photography
Fletcher8
Posted 21/11/2012 - 08:21 - Helpful Comment Link
Hi Shaun
How to get that shot! Which shot would be my starting point. I personally would start with looking through the viewfinder or screen and provide some framing guidelines, rule of thirds, this will at least help people start to understand how to get that shot! As for the more technical aspects such as shutter speed, aperture and focal length I think you would need to write a book.
Not an easy task, but good to be stretched sometimes.
Fletcher8.
Posted 21/11/2012 - 08:42 - Helpful Comment Link
What you write will be dictated by how many words they want.
If there's a particular image in mind then how you got it should be relatively straightforward. Just tell the reader in good, clear English.
mikew
Posted 21/11/2012 - 17:31 Link
puma wrote:
Photography is often a game of odds - the more photos you take; the better your chances are of getting a good photograph.
I'm not sure that's true. Often I find the instinctive reaction gives best results or that really prolonged analysis does but just blazing away creates confusion. Possibly I have misunderstood your advice and you're suggesting that getting into the habit of taking photograph gets your head in the right place and I do think that's good advice.
puma
Posted 21/11/2012 - 18:15 Link
i do mean
And the more you take the more you learn
PPG link
DrOrloff
Posted 21/11/2012 - 18:46 Link
All sound advice. I'll ignore the bit on blue skies though, I seek out grey overcast skies. The greyer and stormier the better. I prefer green and grey to green and blue.
exevalley
Posted 21/11/2012 - 18:53 Link
Taking a photo is more than a case of having a good camera? You do need five things
1. The subject
2. Exposure
3. Composition
4. The right weather or moment
5. And most of all Patience.
Hi Shaun, for what its worth apart from the above I think it makes for good reading, is there another way you can say the above, something like taking a picture is easy you just find a nice subject and trip the shutter release but to make your photo stand out from the average you need five things and then list them.
I think the rest of it is great.
Robin
Posted 21/11/2012 - 19:01 Link
I've learnt (learned?) stuff from your article. Not sure about the getting up early bit
