help - lens stuck
Posted 19/11/2007 - 19:19
Which 50mm lens is it?
Posted 19/11/2007 - 19:20
SMC-M 1.7
Posted 19/11/2007 - 19:55
I can't think how the aperture ring can have any bearing on your being unable to get the lens off the tube. You don't have a young son with a fondness for super-glue, by any chance?
Is the little lever that operates the locking pin on the tube stuck? Or broken? If you can feel it move up and down, I should be prepared to use a reasonable amount of force to twist the lens anti-clockwise.
Posted 20/11/2007 - 09:12
My only thought on this is that you have managed to put the lens on incorrectly. When you move the aperture ring, the linkage will also move to indicate to the body the aperture set for metering. If this is somehow jammed against the receiving pin in the tube, you would experience such a problem.
Kim
Kim
Posted 20/11/2007 - 11:49
I think I have put the lens on wrong - but how? In all my years (22 and counting) of owning Pentax lenses, I've never managed that ...
Posted 20/11/2007 - 12:00
There is always a first time for everything.
Kim
Kim
Posted 20/11/2007 - 12:18
Your best bet is probably to buy another M 50mm. Then you'll have a dedicated macro version, and an everyday walking-around one.
Posted 20/11/2007 - 12:23
I had thought of that
My wife's gonna kill me!
Posted 20/11/2007 - 12:38
Will that work? If the aperture ring is stiff and not turning properly, it would seem that although the new lens would work, the "macro" setup might not.
As an aside, with a 100mm tube, you must be close to or greater than lifesize with a 100 tube. In which case it would be better to work with the lens reversed in any case.
Kim
Kim
Posted 20/11/2007 - 12:51
I'll certainly bear that in mind - if I ever get the damn thing off!
I would really appreciate some help - my 50 mm lens has become stuck on my Pentax 100 mm auto extension tube. It started when the aperture ring felt stiff and odd as soon as I'd put the lens on. Now it won't disengage. The aperture ring won't turn freely either. Any ideas please? Thanks!
