help - lens stuck
Is the little lever that operates the locking pin on the tube stuck? Or broken? If you can feel it move up and down, I should be prepared to use a reasonable amount of force to twist the lens anti-clockwise.
Kim
Kim
My wife's gonna kill me!
As an aside, with a 100mm tube, you must be close to or greater than lifesize with a 100 tube. In which case it would be better to work with the lens reversed in any case.
Kim
I would really appreciate some help - my 50 mm lens has become stuck on my Pentax 100 mm auto extension tube. It started when the aperture ring felt stiff and odd as soon as I'd put the lens on. Now it won't disengage. The aperture ring won't turn freely either. Any ideas please? Thanks!
