Guillotines
Posted 03/04/2008 - 15:46
but then this I use more for school work, so its not as important, although it usually cuts very nicely.
Posted 03/04/2008 - 15:51
But isn't there the risk that the plastic bar will scratch the surface of the print?
Posted 03/04/2008 - 16:12
I use something similar, and have never had a problem with scratches.
Posted 03/04/2008 - 16:18
I have a similar cutter and raise the bar slughtly when inserting the print. I've never had any scratches, it just needs normal care.
Posted 03/04/2008 - 16:38
Same here, I use a similar one and have never suffered scratches.
Joining the Q
Posted 03/04/2008 - 20:02
The only problem could arise if the blade became blunt, and rather than cutting it.. squashed; eek!
Posted 03/04/2008 - 20:37
Same for me.
Hyram
Posted 03/04/2008 - 22:12
Excellent - unless eBay can produce a bargain solid lever style I'll go with a decent quality rotary guillotine.
Thanks guys.
Thanks guys.
Posted 04/04/2008 - 12:19
I use one of these at work:
http://www.rotatrim.co.uk/product.php?product_code=4
But I still use a cutting matt and craft knife for precision cutting.
K5, LightRoom 5
Posted 04/04/2008 - 12:26
Key phrase 'at work' - I'm not spending that kind on money! As for knives I find that blood puts people off pictures
Posted 04/04/2008 - 13:37
What about these:
http://www.rotatrim.co.uk/product.php?product_code=171
Don't worry about the blood - you've got around 8 pints ............ and plasters are cheap!
K5, LightRoom 5
Posted 04/04/2008 - 14:03
That's more like my money.
I'll see what my local sationery supplies can do. I expect he'll do the spray mount and card as well although he may not be competitive.
Posted 05/04/2008 - 00:54
I own a printing shop, so I don't think you are going to use what I'm using. It is a Schneider Senator 115cm, but it wouldn't even fit through your door.
Worcestershire
I have used a rotary guillotine but I don't like the potential for damaging the surface while the lever action ones seem old hat.
I used to have access to a power cutter which was great if scary but no longer.
Any advice?
