GGS Screen Protector For A Samsung GX10
malvern_man
Posted 26/02/2011 - 17:17 Link
Hi all,
Does anyone know if the K20D GGS screen protector will fit a Samsung GX10 or are the screens a different size / shape.
I'm struggling to find a dedicated GX10 one.
Regards, Chris.
prsjnb
Posted 26/02/2011 - 18:10 Link
It doesn't have to be 'dedicated' it just has to fit: I got one for my GX10 here:
link
Edited by prsjnb: 26/02/2011 - 18:13
carmagw
Posted 26/02/2011 - 20:02 Link
I had similar problems with my GX20 and put a K20D one on.
Although the viewable areas are the same between the K20 and GX20, the actual shape of the back plastic/screen are slightly different. The GX20 being slightly more curved on the left and right hand edges and possibly taller although I don't have a K20d to compare it to.
The K20D GGS screen protector has straight edges and rounded corners so overhangs very slightly at each corner and has a slightly smaller height (bottom third of the word SAMSUNG sticks out from the bottom)and width.
Although other than when I first put it on, its not really noticable and does a fine job protecting the screen.
As you have a GX10 you will probably need the K10D screen protector as the screens are bigger on the K20D.
George
felix
Posted 27/02/2011 - 10:29 Link
malvern_man wrote:
Hi all,
Regards, Chris.
Get the protector for the K10D as it is 2.5 " in size, the K20D is 2.7"
xbow
Posted 27/02/2011 - 11:26 Link
If you are good with a pair of scissors or better still a craft knife try these?:
link
Vic.
K5, LightRoom 5
malvern_man
Posted 27/02/2011 - 16:16 Link
Thank you all for the help and info.
I've ordered the generic 2.5" glass protector from the link prsjnb posted.
Regards, Chris.
diddle
Posted 16/07/2011 - 21:37 Link
I used a xoskins screen protector on mine. Military grade with no orange peel.
diddle
Posted 16/07/2011 - 21:38 Link
Forgot to add the link.. screen protector
