Genuine M42 adapter
The latest just say "PENTAX" at the top and "JAPAN" at the bottom.
Simply remove the spring and throw away the plate and the bayonet fixing is on/off - but beware there is NO latch
regards
Bernard
Wondering if I'm not using it correctly or somethings up with it
When you want to remove the adapter just operate the small catch with the tip of a ballpoint pen, or indeed a small screwdriver, and rotate the adapter. If you hold the camera throat downwards the adapter should fall off into your hand.
Hope that helps!
Lancashire
Thanks,
John.
