Galatea - November 2017
Posted 23/11/2017 - 12:58
That is a pleasing composition Mike and well timed too.
I often purposely under expose steam loco shots to preserve the detail in the steam but then adjust the shadow/highlights in post-processing.
You have a choice of two steam trains into Chester on Saturday:
70013 'Oliver Cromwell' coming from the Wrexham direction...
http://www.uksteam.info/tours/t17/t1125a.htm
60163 'Tornado' coming in from Crewe...
http://www.uksteam.info/tours/t17/t1125b.htm
Pentax K5
Tamron 80-210mm & 28mm
Pentax K5
Posted 24/11/2017 - 11:30
Yes, I'm not familiar with the line from Wrexham so I figured I'd go for Tornado instead. Weather seems to be looking good for tomorrow.
I was quite pleased with catching that between the trees. Of course, one of the other shots has a telegraph pole slap bang in the centre of the loco, so not quite as good. I must confess to editing out some wires across the shot, and a lot of birds that make the lens look very dirty.
South Cheshire
I've played around with it a bit, and I'm also not sure I haven't over-darkened the sky.
As usual, any comments or critique are welcome, I'm out again at the weekend as Tornado is passing. Not sure whether to go for the same location or try somewhere different.
