Focusing problem
Posted 26/04/2018 - 09:30
Algernon wrote:
SR is designed for around 1/30th sec. or slower. It usually doesn't have much effect at high speeds. I once saw some tests on a website that showed this applied to all makes.
Some scientific proof for the doubters SR is designed for around 1/30th sec. or slower. It usually doesn't have much effect at high speeds. I once saw some tests on a website that showed this applied to all makes.
http://blog.falklumo.com/search/label/shake%20reduction
Posted 26/04/2018 - 15:47
Interesting articles. This backs up my own experiences. Worth pointing out that they found no evidence that SR has a detrimental effect at faster shutter speeds.
Posted 26/04/2018 - 16:25
With the K-5IIs and previous cameras my keeper rate on jets using a high shutter speed and full FPS was certainly better with SR off than on, I always found quite a few in the sequence showed quite a bit of shake.
How better my current cameras are (K-3II and K-1) I couldn't say as I haven't used them at an air show yet, due to weather constraints I didn't go to any last year.
Posted 26/04/2018 - 17:39
I guess there is the possibility that if the SR is not fully activated (my K10 would take a noticeable time to activate) then it possibly could have a detrimental affect on the picture, but this is pure speculation on my part.
I always kept SR on (except for tripod) with the K10 and do the same with the K1.
Posted 01/05/2018 - 19:36
StephenHampshire wrote:
I photograph a lot of trains and use back button AF all the time. Was SR on? I have had some instances where shots in the middle of a sequence are soft (overall soft rather than just mis-focussed) which I blame on the SR still moving the sensor
I have been thinking of getting the DA* 50 -135 but the K3 can shoot at 8.3 fps and the autofocus on the 50 - 135 is described as slow, have you experienced this with any lenses that you have? It seems to be an odd combination.
DA AL 35mm f2.4, K3,18-135 WR, DA 55-300, Pentax KX, K5 x 2, 18-50 50-200 kit lenses, Tamron 17-50 f2.8, Fuji X10, 2x Mamiya 1000s 2x 80mm f2.8, 150mm f3.5, 210mm f4, Yashica 124G TLR, 2x Yashica FX3 Super 2000, Tamron 28mm f2.8, 90mm SP f2.5, 135mm f2.5, Olympus 35RC, 2x Yashica FX2, Kodak Pocket Instamatic, Kodak Box Brownie
Posted 01/05/2018 - 20:49
sportyman531 wrote:
I'm afraid I tend to use my Sigma 50-150 f2.8 which has motor focusing and is very fast - or the 16-85WR. I used to use the 18-135 WR but the 16-85 is sharper
I have been thinking of getting the DA* 50 -135 but the K3 can shoot at 8.3 fps and the autofocus on the 50 - 135 is described as slow, have you experienced this with any lenses that you have? It seems to be an odd combination.I photograph a lot of trains and use back button AF all the time. Was SR on? I have had some instances where shots in the middle of a sequence are soft (overall soft rather than just mis-focussed) which I blame on the SR still moving the sensor
Everything Changes
https://www.flickr.com/photos/arleimages/
Posted 04/05/2018 - 09:50
There is a thread on this forum with a K3 displaying similar issues https://www.pentaxforums.com/forums/58-troubleshooting-beginner-help/365452-its-...
Posted 05/05/2018 - 00:30
This may not be relevant to this issue - I've had a similar problem with my K-5 in the past when using manual focus lenses (more correctly - lenses that don't communicate focal length). If you don't set the focal length correctly, SR won't apply the correct 'corrections'. In my case it was set to 1500 with a 50mm lens on the front - SR was over-compensating hugely, blurring everything.
Might be an idea to check that the camera reports the correct focal lengths in the EXIF.
Posted 07/05/2018 - 22:20
pgweber wrote:
Going back to what the OP said in the beginning, I am not convinced that once the focus has been set (either by shutter or AF button) that the camera will maintain that focus position. i.e. on my K5, I think the focus position will move.
Stephen, can you confirm if you used the AF button to pre-focus?
Not really pre-focus, I focus as I need. In a burst I might pres the back button 3 or 4 times, release and press the shutter- basically using the af button and AF/S to achieve AF/C but under my control
Everything Changes
Posted 02/10/2018 - 22:20
Update:
I wasn't able to identify what the specific problem was but I contacted SRS who asked me to send some sample pics. As the camera body was still under warranty, just, they then advised me to return it for service/repair, which I did. It came back from Johnson's Photopia with a note that, "Checked to specification, unable to re-create fault - Updated Firmware". I have used it a few times since and so far everything has been OK.
12 years
Warwickshire
