Flash trigger versus shutter trigger.
Gene-Stevo
Posted 21/06/2012 - 23:07 Link
Hi Guys, I've managed to rig up event triggers for off camera flash by completing the circuit between centre pin and edge contact of my 360fGZ. Easy-peasy, just add some form of switch (I'm talking about when not using pop-up as a control).
What I need to do though is the same sort of thing for triggering my shutter (K-7). I have a type F remote but need to rig up a wired switch to trip the shutter when a set of remote contacts are closed.
The question is, can I set up the same simple switch system to fire the shutter as is used to fire a flashgun? Could I perhap abuse a wired cable switch (CS-205) to this purpose? Or, if I can find a supplier of the CS-205 type jack plug, make my own.
Cheers,
Gene-Stevo.
DoctorJeff
Posted 22/06/2012 - 09:02 - Helpful Comment Link
You can get 2.5mm stereo jack plugs from Maplin (and sockets too if you want to make an extension lead).
There are plenty of instructions on the 'net - but most of them refer to making up a switch for Nikon (boo, hiss :mrgreen rather than Pentax.
Your biggest problem will be getting hold of 3-core cable.
Ebay abounds with CS-205 rip-offs, and many of them have rather cheap switches (but you would get a 2.5mm plug and cable) or you could buy a used Pentax Cable Switch F (as used on many of the pre-digital AF Pentaxes) and thus be able to use a Maplin plug with the correct cable and a quality switch. There are often Cable Switch Fs on offer here (or you could just post a wanted ad).
Geoff
X-5
istDS
K2000
P50.
Pentaxophile
Posted 22/06/2012 - 10:05 Link
Can't really help but interested as to why you'd go down this route rather than the wireless remote which only costs a few quid, and for that matter, wireless flash triggers (actually doesn't the 260fGZ have wireless capability built in anyway?)
Posted 22/06/2012 - 13:25 - Helpful Comment Link
This thread may help
I've seen 'mashups' with the radio flash receivers wired into the remote so you can press the transmitter to take a shot. IIRC, the Yonguo flash triggers feature this already.
Gene-Stevo
Posted 22/06/2012 - 20:48 Link
Thanks to all for responding. Found something akin to MattMatic's link relating to Canon triggers which also related to Pentax. Who'd have thought?
The reason I need this route is that I'm going to do some arty/farty stuff with flying liquids/sliding tables etc. The event will trigger the shutter which will inturn fire the flash rigs. I could theoretically engineer something to press the button on my type F remote when the "event" happened but that would be a real faff and be very difficult to calibrated for the inevitable timing issues.
Thanks all again for your assistance.
Pentax forever.
Eugene.
