Fixing a busted lens
Posted 14/08/2008 - 21:14
If I remember correctly, you need a rubber bezel removing tool to twist the bezel off (the round plate that shows the lens data and sits between the glass and the filter thread). The filter threaded shroud I believe is held in place by a few screws. Tighten the screws and refit the bezel.
I think it should be as simple as that . . . but it might not be.
The lens I fixed was a SMCP-A 50mm 1:1.7 and might be a bit different to yours.
Posted 14/08/2008 - 22:13
Whenever I take anything to pieces and put it back together I always end up with a spare screw!...........good luck my friend
Posted 14/08/2008 - 23:17
The rubber tools used for removing bezels aren't exactly thick on the ground and probably not worth buying for a one-off job, however, if you have a walking stick (or similar) to hand you can usually improvise by using its rubber foot.
Good luck!
Good luck!
Joining the Q
Posted 14/08/2008 - 23:25
I made one of those rubber removal tools by modifying a large rubber bung (stopper) and it worked ok.
Sdeve I have sent you a PM.
Camera:|K-7|
Posted 15/08/2008 - 02:45
I posted a how-to a while back, using a rubber pipe fitting from a hardware store...costs like $2.00
Posted 15/08/2008 - 16:24
For some reason, I can't read my original post, or the PM.:
Or my last post!!
Posted 15/08/2008 - 23:08
For some queer reason i get this sometimes. I just scroll up and then back down and the text appears. For some reason, I can't read my original post, or the PM.:
must be some sort of security feature or i have an intermittent blindness problem
Camera:|K-7|
I'd like to have a go at fixing it to use for flash portraiture on my K200D.
Anyone know how to get these to bits (in a way that I can get it back together again)?
