Firmware updates!
Once copied disconnect your camera from the PC, ensure you have a full battery, put the SD card back in the camera and switch it on while pressing the menu button then follow the onscreen instructions. Do Not switch off the camera until it is complete.
http://www.ricoh-imaging.co.jp/english/support/digital/k10d_s.html
It has the download link and instructions.
The main thing is copy the downloaded fwdc162.bin file to the route directory of the SD card, but the text file with the download should give full details.
If not report back if it still doesn't make sense!
The UK site just seems to have the download files but not always the instructions.
Please ignore my last rant! I've finally sorted it after much hair pulling and a refusal to let it beat me! I had downloaded the files onto the SD card incorrectly. I suppose it doesn't help being completely up there in the IT Dept!
Thanks again and Merry Christmas - both cameras now sitting next to me updating!!
Chris B
I have spent the last hour trying to update my K3. For some reason pressing the Menu Button whilst switching on the camera does not display the current firmware version, nor start the upgrade process either?
Is the K3 different from the K10-K20-K7 or the K5 in the way an update is applied. Just checked with the K5 and pressing Menu at startup shows the current version. K3 refuses to play using that combo. Can see the firmware version by going through the menu screen.
Going to take the Christmas tree down now and pack it away for another year. Hope someone may have some advice re the K3 update problem I have by the time I log in again.
Knowing my luck it's a camera fault?
OR, it could be an age thing
Retired at last - now all that time for photography - you would think: wink:
Both cards formatted and placed back in the camera - still not showing firmware option when using menu and power button combo?
Camera appears to work normally in all other ways
K1 II|K3|DA10-17|DA*16-50|FA31|DA*50-135|DA*200|DA*300|Sigma 150-500
Chris, thanks for posting your problem with an update...I am not alone!!!
I was using the extracted bin file. Via the Menu page it is possible to see the current firmware version - but it is read only, no option to start an upgrade.
Thanks for the input
I don't think the K3 displays the firmware version using the Menu/power on combo, at least mine doesn't before or after the update. Out of interest which file are you putting on the SD card? Is it the unzipped .bin file or are you trying to use the compressed .zip or .exe file?
Chris
