Filter removal
Posted 27/09/2011 - 12:41
What have you tried?
Posted 27/09/2011 - 12:49
Just the usual really.Not much to grab hold of though
I have a very limited grip though.
Chris.
Chris.
Posted 27/09/2011 - 12:51
Have you tried using rubber gloves for more grip?
Posted 27/09/2011 - 12:56
Rubber gloves is an excellent idea - works on jamjars too! there are also lens filter wrenches available for stubborn filters - they are only a couple of quid I think. Worth a look on ebay or a camera accessory website I reckon if the rubber gloves don't work.
EDIT: This is the sort of thing... link
Posted 27/09/2011 - 13:03
Thanks. The long barrel on this lens means that there is a lot to hold but I felt unsure about how much punishment it would take.
Will look for removal tool and gloves.
Chris
Chris
Posted 27/09/2011 - 13:11
Soften up some Blu-Tak by leaving it stuck to the side of a
kettle that's recently boiled or hold near to a fire/radiator.
Roll it into lengths about 5mm diam.
Stick it on the edge of the filter rim, so the rim is fully
covered.
Place lens perpedicular to a Formica topped or glass table.
Push down so Blu-Tak grips the table.
Unscrew carefully by turning lens.
Don't do it again
covered.
Don't do it again
Posted 27/09/2011 - 13:15
Place a rubber mat on a table.
Push the lens with the stuck filter down onto the rubber mat. Twist the lens anti-clockwise.
You can buy jar top removers from kitchen-ware shops. I have also seen these in Pound Stores. These are a plastic handle with a rubber belt.
Friendly Regards
Graham
Graham
Posted 27/09/2011 - 13:39
One thing to watch out for is gripping the filter too hard on opposite sides - this distorts the rim and locks it more firmly in place.
Posted 27/09/2011 - 13:49
If it's been on for 18 months, any special reason why you want to take it off now?
Might just be best to leave it as is.
Posted 27/09/2011 - 15:01
The bottom of a mouse mat is often an ideal grippy surface to use too - push the filter down onto the mat and unscrew it that way. Just make sure that you grip a part of the lens that's directly connected to the filter ring so that you don't strip any helicoids or internal gearing - that goes for all the methods mentioned above too!
Posted 27/09/2011 - 15:12
John
I just noticed that there was a little bit of dust present.
I think that because it is cross threaded it makes it a lot more difficult.
Most of the removal techniques are beyond my ability(due to disability)but will try what I can. Thanks for advice.
Chris
Chris
Posted 27/09/2011 - 15:17
covered.
Don't do it again
2nd vote for this method...it's what I've used in the past.
covered.
Don't do it again
Posted 27/09/2011 - 15:30
Also found that placing an ice cube on the filter for a few minutes helps. Presumeably by shrinking the aluminium frame a smidge.
Then use Blu-tak/rubber mat as above
regards
Bernard
regards
Bernard
West Wiltshire
Chris
