DA-star and problems with extension tubes
Posted 08/09/2011 - 12:46
Peter - I've tried both the DA*16-50 and DA*50-135
I reckon it's not tolerance, but down to the body expecting SDM communication from a lens that it knows is SDM
If I put an SMC-A 50/2 on the end of the same tubes then everything works absolutely perfectly
That's why I'm hoping I can get the body to see the DA* as an SMC-A style lens... maybe! (Better still would be a firmware update!)
Posted 08/09/2011 - 12:53
I have a set of auto Hoya tubes, without the electrical contacts, that work fine on my istDS and K10D, i.e they allow the lens to stop down during exposure.
For some reason this doesn't work on my K7, it stays wide open, no matter what f-stop I have chosen.
Anyway, thanks to your idea of starting to remove the lens/tube, I can get it to at least operate at my chosen f-stop.
Not exactly what you were trying to do, but has got me out of a hole, thanks.
John.
John.
Posted 08/09/2011 - 13:11
John,
Do your tubes have the aperture 'finger'?
Pentax produced manual tubes, and 'auto' tubes. The manual ones were just a tube, and the auto ones have the mechanical linkage for the aperture lever.
AFAIK, only third party ones have electrical contacts, and there is only one (very rare) Kenko 25mm tube that has PZ contacts (i.e. the SDM contacts).
Wouldn't mind trying the Kenko ones
Posted 08/09/2011 - 13:17
A bit of Googling for the "rarer than hen's teeth" Kenko Uniplus 25DG came up with this thread:
So there may be hope...
However, you can use any extension tube that has the contact pins but does not have the powerzoom contacts (used to drive SDM) by shorting out the data pin (the very bottom pin as you look into the camera) and using catch-in-focusing. By doing this you can use any autofocusing lens on Pentax K10D, Pentax K200D, Pentax K20D, and a Pentax K-7. See my thread at:
]http://forums.dpreview.com/forums/read.asp?forum=1036&message=35995640
Posted 08/09/2011 - 14:58
Hi Matt, yes they do have the aperture 'finger', and as I say they work with all my other cameras as expected, but not with the K7.
It's funny if I take the M 50mm f1.7 lens off the tube, and put it on the K7, it works ok.
I've tried the tubes with a few lenses, and they all work ok on the other cameras, but not on the K7.
Must be the tubes They are Hoya, but made and purchased before the 'take-over'
Posted 08/09/2011 - 18:26
I've tested my Kenko tubes (labelled: KENKO EXTENSION TUBE FOR P/AF, which is a bit of a misnoma because they lack both SDM contacts and the AF screw) as per Matt's configuration, but only with the DA* 16-50mm lens.
They behave exactly as Matt has described, identically to his Teleplus tubes.
I've not gone any further with this because my macro lenses, which is what I would use anyway, perform as expected and give me focus confirmation when the body is in MF mode.
It shouldn't be beyond Pentax's expertise to allow us to choose which AF drive method we prefer, especially when some DA* lenses have both SDM & screw methods for focussing.
It'd be interesting to know what happens when a pre-SDM body is used. I guess it'll work fine.
Posted 08/09/2011 - 20:14
John.
You're not suffering this problem (link) are you?
John.
Lurking is shirking.!
Posted 08/09/2011 - 21:34
Matt is wonderful
Liking the macros of the watch.
Posted 08/09/2011 - 22:54
dougf8 wrote:
Mannesty wrote:
Peter, you're a star and Matt is wonderful dougf8 wrote:
Matt is wonderful
Excuse me but, whilst I agree that Matt is wonderful, check out this thread . . . from 4 years earlier.Matt is wonderful
24 years
Sussex,
UK
The problem is that the Teleplus (sorry: Teleplus) tubes I have - which have the electrical contacts - seem to freak out the K5. Now, it did it with the K7 and IIRC the K20D as well. It's almost like the camera is confused, knowing that the lens should be SDM focused, but not able to communicate.
Now, I'm not one to take this without a fight
So, first thing: switch the lens or body to the MF setting. When the lens is on AF, the "MF" sign flashes madly in the viewfinder. (But I've lost focus confirmation ability!) With that, I can take shots through the viewfinder...
...but, odd things are going on. Holding a button down doesn't auto-repeat anymore (unless you slightly dismount the lens). Oh, and Live View doesn't work - the camera just opens and closes the shutter. Pah
I did manage to get it to work by holding the lens release tab and slightly rotating the lens.... but it's not working all the time
It's such a shame that Pentax can't update the firmware to allow for this situation. But, I admit it's low down on their priority - supporting a third-party extension tube!
My only other option is to modify the tubes to mask out one of the contacts - so the body thinks it's got an unidentified lens attached that still supports "A" aperture.
Will keep you posted
