Filter cleaning
Renster
Posted 03/02/2013 - 10:08 Link
Hi guys,
I was out walking with the dogs last week, one of them managed to flick a spot of wet mud onto the clear filter of my sigma 10-20.
I left it well alone until I got home. It had dried solid by that time so I soaked it until soft again and gently wiped it away with my finger ensuring not to push it across the glass. It doesn't appear to have scratched the glass but if you hold the filter at certain angles to the light you can see a smear / water mark. I don't think it will affect image quality but being as its a fairly large / expensive filter I would like to get it back to new if possible.
I've tried a lens brush and pen but can't seem to shift it.
Any ideas?
steven9761
Posted 03/02/2013 - 10:13 - Helpful Comment Link
Try an alcohol wipe (the kind they use in hospitals). The isopropyl alcohol will freely evaporate, leaving the glass clean.
Renster
Posted 03/02/2013 - 10:23 Link
That's great, I'll give it a to later. I was a bit worried about applying any kind of chemicals in case it affected the surface .
Renster
Posted 06/02/2013 - 19:34 Link
I got some wipes and it's now back to new! Excellent bit f advice! Cheers Steve!
nanhi
Posted 01/04/2013 - 06:02 Link
Hi Renster Sir, that was good news getting rid of the smear. But what wipe did you use?
I had a similar problem once, so I used the next best thing I had - Sears Lens Fluid, and it worked. I have lots of old filters, and prism lenses (multiple images) which I don't use much. I found them with some kind of fogginess on them. They cleaned up pretty good with the Sears Lens Fluid.
CAUTION: Never use Hospital Alcohol or Rectified Spirit, as they have some kind of oily additive in them.
At one time I bought Kodak Lens Cleaning Fluid and Lens Tissue.
Regards.
Renster
Posted 01/04/2013 - 08:26 Link
Hi nanhi, I used lens wipes that I bought from boots pharmacy.
Algernon
Posted 01/04/2013 - 09:59 Link
ROR is about the best lens and filter cleaner.
It also cleans camera bodies.
http://www.ror.net/
Available from:
http://www.newprouk.co.uk/ROR-lens-cleaner.html
Edited by Algernon: 01/04/2013 - 10:13
fatspider
Posted 01/04/2013 - 10:42 Link
I also use lens wipes, the ones I currently have came from a discount shop and IIRC cost me £1.99 for 100. The brand name was Zeiss although I doubt they are from the camera manufacturer of the same name
Not had any problems with them whatsoever and they're also invaluable if you wear glasses too.
My PPG link
My Flckr link
Algernon
Posted 01/04/2013 - 11:50 Link
If it's really dirty send it to this man
