Balsam separation?
Posted 04/10/2012 - 09:41 - Helpful Comment
A top lens specialist may be able to fix it, but it won't be cheap.
Try an email to: http://www.thelensdoctor.co.uk/
Posted 04/10/2012 - 11:40 - Helpful Comment
Barrie - Too Old To Die Young
Posted 04/10/2012 - 11:51 - Helpful Comment
It's a very expensive lens, so maybe worth getting a quote for repair, but it will be a specialist job.
However, in the meantime, some special effect shots may be the way to go. How does it handle street lighting and other low light shots? Perhaps there's something interesting could be done with dramatic landscapes?
Posted 04/10/2012 - 16:35
Thanks Algi, I have sent them an e-mail!A top lens specialist may be able to fix it, but it won't be cheap.
bforbes wrote:
It seems people do try DIY
http://www.pairlist.net/pipermail/largeformat/2005q3/019094.html
I have attempted DIY on some lenses, and without exception I have done more damage than repair...
That is a creative idea, I will for now definitely experiment with some special effects shots!It's a very expensive lens, so maybe worth getting a quote for repair, but it will be a specialist job.
Thank you all for your help!
Posted 01/04/2013 - 07:28
Balsam was used ages ago to join two lens elements. It has a refractive index same as glass so was very popular then. But aging affects the glue and separation starts from the lens periphery. This will show up as flare and blur around the edges.
I had a Zeiss binocular with this problem. Just soaked the lens in alcohol for a week and pried the two lenses apart. Removed the balsam coating by gently scraping it with my nails. Cleaned the surfaces with alcohol. Put the lenses together without any gluing and and assembled it back. Worked fine.
Did not notice any perceptible difference except for some slight color fringing between the two eye pieces.
Here is the cheapest source for a possible repair. Do tell them to apply multi coating too. He did an excellent job for of re-coating an old Rolleiflex f2.8 Planar lens. The only condition is you send him the glass and NOT the lens, since he is a manufacturer of optical glass and not a repairer of lenses:-
Mr. Mukul Garg
http://www.universaloptics.in/ [email protected]
UNIVERSAL OPTICS.
D-1, INDUSTRIAL ESTATE.
ROORKEE - 247667.
(UTTARAKHAND)
INDIA
Here is a guy in the US. But be prepared to pay 4-times as much:-
Focal Point Inc.
303-665-6640
[email protected]
300 Center Drive
Suite G-177
Superior, CO 80027
Check out some of the old Russian Federation countries too. Cheap and very good.
Mr. Mukul Garg
UNIVERSAL OPTICS.
ROORKEE - 247667.
(UTTARAKHAND)
INDIA
Focal Point Inc.
303-665-6640
[email protected]
300 Center Drive
Suite G-177
Superior, CO 80027
Posted 01/04/2013 - 09:46
Yup. Top lens in most microscope eyepieces is a cemented doublet and I've seen it separate countless times. Schools generally aren't in a position to keep buying eyepieces and so it's clean and rebuild dry. I've done the odd one with immersion oil too, no colour fringing that way.
/but I wouldn't try an oil film inside a camera lens, too much chance of it making it's way into the diaphragm...
Posted 01/04/2013 - 12:36
I do not know if this repairer does the sort of repair you need, Bjolester but it may be useful in case you need it.
http://www.ajjohnstone.co.uk/
Dave
Dave
Trondheim,
Norway
The lens is otherwise in mint condition, and is worth having anyway
I am grateful for any help!
Bjørn
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/K15.jpg[/IMG]
f5.6
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/K15_f56.jpg[/IMG]
f22
[IMG]http://i812.photobucket.com/albums/zz50/bjolester/K15_f22.jpg[/IMG]
